2 members (Maybellene, Peggy M),
124
6
Mod | | | Forums66 Topics128,284 Posts1,058,531 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Mig is my go to for just about all of my usual fab work except aluminum. Got to admit, it's also the easiest to learn. Several years ago I was working on a door. The PO had buggered up the garnish molding screw attachment hole around both windows. I decided to mig a small amount a metal into the buggered holes to ' close' the hole up a bit. I quickly realized how hard the mig weld material was. The sheet metal screws were not about to cut new threads through the welds. It took some work to get the hole round again. I worry about hammering the mig stitch welds flat. Test panels sounds like a good idea. I'll try the different types on the panels and see what works for me. Off shore stuff again! I've had two incorrectly machined wheel cylinders and an incorrect starter solenoid in the past two weeks.
Entire Thread
Sheet metal welding, which kind is best?
| beltfed | 06/22/2016 11:31 PM |
Re: Sheet metal welding, which kind is best?
| Hotrod Lincoln | 06/22/2016 11:45 PM |
| Deve | 06/23/2016 12:11 AM |
| beltfed | 06/23/2016 2:45 AM |
| Hotrod Lincoln | 06/23/2016 3:37 AM |
| 52Carl | 06/24/2016 1:52 AM |
| Deve | 06/24/2016 2:35 AM |
| showkey | 06/24/2016 1:55 PM |
| bartamos | 06/24/2016 9:08 PM |
| 52Carl | 06/25/2016 3:50 AM |
| beltfed | 06/25/2016 2:05 PM |
| bartamos | 06/25/2016 7:30 PM |
| beltfed | 06/25/2016 10:43 PM |
| bartamos | 06/25/2016 10:46 PM |
| Hotrod Lincoln | 06/25/2016 11:15 PM |
| Deve | 06/25/2016 11:54 PM |
| Don | 07/07/2016 5:27 AM |
| Allen Lane | 07/08/2016 1:07 AM |
| thoroco | 07/08/2016 10:13 PM |
| Allen Lane | 07/09/2016 1:23 AM |
| thoroco | 07/09/2016 4:03 AM | |
