Not sure if this will help but this is what I did to put a pull throttle cable to my 4 barrel in the 52 panel.
I took a 3/4" wood dowel and cut some pieces at different angles to get it to fit the recess and be "flat" where the cable comes out. I can't remember the angle but once you get it then you can cut the piece that goes through the firewall depending on the type cable you use. I use a Lokar pull cable/pedal ect.
....did any of this make any sense to you?
