| | | Forums66 Topics128,140 Posts1,056,464 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | JW51, The 207 shares all of the engine internal parts with the passenger cars, so parts can be found (manifolds, carb and Gen will be different). 1936 was a transition year for the 1-1/2 ton truck brakes...early production still had mechanical brakes before swapping over to hydraulic mid-year. All 1/2 ton had Hydraulic. The High Cab has 3-hinges per door while the Low Cab has two. Also the top of the Low Cab has rounder/softer corners. Hope this helps, Mike B  | | | |
Entire Thread
1936 considerations - engine, brakes, cab, etc.
| JW51 | 01/11/2016 7:21 PM |
Re: 1936 considerations - engine, brakes, cab, etc.
| Mike B | 01/12/2016 1:02 AM |
| JW51 | 01/12/2016 1:42 AM |
| Mike B | 01/12/2016 1:51 AM |
| JW51 | 01/12/2016 2:05 AM |
| Mike B | 01/12/2016 2:19 AM |
| 1936only | 01/12/2016 8:46 PM | |
