1 members (Otto Skorzeny),
54
3
Mod | | | Forums66 Topics128,054 Posts1,055,779 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Not sure on yours but some vents are screw in some are pressed in. Are you sure yours is stopped up?? I think its rare if it is. ...and yes, a couple vendors make the vents but not sure if they are for a torque tube as well as for a rear housing.
If its not over full, I go along with rickmg. The seals are bad, or perhaps the bearings are bad and causing the seals to leak. Are you having any rear axle noise? Maybe you'll be lucky and just the seals bad. | | |
