| | | Forums66 Topics128,290 Posts1,058,565 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | There is more than one way to skin the rat as it were. Here are some diagrams for different signal stats. From a Jeep site but the same principles apply: http://cj3b.info/Tech/SignalWiring.htmlAt the bottom of the page is a link to the "Tech Tip" from this site. And to clarify, the power from the brake switch comes after the switch. I know sounds funny, the switch has to function to tell the signal stat the brake pedal is depressed. So power to the brake switch. Then from the other side power for the brake input on the signal stat. The old brake light wire that used to go from the switch to the brake lights is not hooked to the brake lights any more. It goes to the signal stat and, then goes to the tail lights. The problem is the existing brake light wires running under the truck. Those are the wires I suggested you disconnect for the testing. I don't think the signal stat is bed yet. There is more to troubleshoot before you get to that point. Follow the wires carefully. Use an Ohm meter to confirm all connections are right. Good luck and let us know how you do.
Steve H
Entire Thread
Taillight, brake, turn signal wiring
| 5H4N3 | 12/30/2014 8:02 AM |
Re: Taillight, brake, turn signal wiring
| DADS50 | 12/30/2014 3:09 PM |
| 5H4N3 | 12/30/2014 4:29 PM |
| DADS50 | 12/30/2014 8:17 PM |
| bztguy | 12/31/2014 12:20 AM |
| truckernix | 12/31/2014 11:35 AM |
| 5H4N3 | 01/01/2015 7:06 PM |
| 5H4N3 | 01/03/2015 12:18 AM |
| Flxible | 01/03/2015 12:49 AM |
| 5H4N3 | 01/03/2015 2:23 AM |
| 5H4N3 | 01/06/2015 5:13 PM |
| Shaanxi | 01/08/2015 2:04 PM |
| DADS50 | 01/08/2015 2:19 PM |
| Steve_H | 01/08/2015 4:58 PM |
| Shaanxi | 01/09/2015 5:47 PM |
| DADS50 | 01/09/2015 6:49 PM |
| Shaanxi | 01/10/2015 2:08 PM |
| Steve_H | 01/10/2015 10:03 PM |
| Shaanxi | 01/11/2015 11:06 AM |
| Shaanxi | 01/11/2015 7:17 PM |
| Steve_H | 01/11/2015 8:03 PM |
| Shaanxi | 01/12/2015 10:07 AM | |
