| | | Forums66 Topics128,290 Posts1,058,565 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 168 Shop Shark | | Shop Shark Joined: May 2013 Posts: 168 | Ok. Worked on this a bit today. I did as suggested:
1. Ground the signal switch: fixed the problem with the indicator light on the switch itself. 2. When you say 'just tie them to the brake lights'....What I took this as to do was to put a jumper wire from the turn signal wire to the stop light wire on both sides. This did not fix the problem. Instead I had a variation of all three bulbs on each side illuminating.
So, still when I switch on the ignition key switch, the flashers immediately start flashing, except it alternates between STOP and RUNNING on the rear. If I pull out the plunger switch to activate the flashers, it operates normally. Placing the turn signal lever in the cab to turn left or right, it stops the flashers, but does nothing else......UNLESS, I turn on the headlights with the right turn signal ON, THEN the front right signal flashes, but not the rear.....
I'm at a loss.
1953 3100
Melbourne, FL Veteran
Entire Thread
Taillight, brake, turn signal wiring
| 5H4N3 | 12/30/2014 8:02 AM |
Re: Taillight, brake, turn signal wiring
| DADS50 | 12/30/2014 3:09 PM |
| 5H4N3 | 12/30/2014 4:29 PM |
| DADS50 | 12/30/2014 8:17 PM |
| bztguy | 12/31/2014 12:20 AM |
| truckernix | 12/31/2014 11:35 AM |
| 5H4N3 | 01/01/2015 7:06 PM |
| 5H4N3 | 01/03/2015 12:18 AM |
| Flxible | 01/03/2015 12:49 AM |
| 5H4N3 | 01/03/2015 2:23 AM |
| 5H4N3 | 01/06/2015 5:13 PM |
| Shaanxi | 01/08/2015 2:04 PM |
| DADS50 | 01/08/2015 2:19 PM |
| Steve_H | 01/08/2015 4:58 PM |
| Shaanxi | 01/09/2015 5:47 PM |
| DADS50 | 01/09/2015 6:49 PM |
| Shaanxi | 01/10/2015 2:08 PM |
| Steve_H | 01/10/2015 10:03 PM |
| Shaanxi | 01/11/2015 11:06 AM |
| Shaanxi | 01/11/2015 7:17 PM |
| Steve_H | 01/11/2015 8:03 PM |
| Shaanxi | 01/12/2015 10:07 AM | |
