| | | Forums66 Topics128,290 Posts1,058,565 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 29 New Guy | | New Guy Joined: Dec 2013 Posts: 29 | I'm wiring my original 6v system on 1950 Chevy 3100 with reproduction taillights and doing toggle switch turn signals. The problem I'm running into is, the housing has 2 single filament bulbs so I need to run the turn signals and brake through the same wire.. This site is the only one I've found that seems to have a solution, it's suppose to have the turn signal override the brake. http://www.how-to-build-hotrods.com/turn-signals.htmlI got the adapter piece but it doesn't work. Bypassing the adapter, the brakes and turn signals work independently when hooked up to the lights. With the adapter hooked up though neither the brakes or turn signals work. So it is definitely something with the adapter and my money's on I just received a defective one or its a 12v adapter or something but couldn't find out if voltage mattered with adapter anywhere.
Entire Thread
Taillight, brake, turn signal wiring
| 5H4N3 | 12/30/2014 8:02 AM |
Re: Taillight, brake, turn signal wiring
| DADS50 | 12/30/2014 3:09 PM |
| 5H4N3 | 12/30/2014 4:29 PM |
| DADS50 | 12/30/2014 8:17 PM |
| bztguy | 12/31/2014 12:20 AM |
| truckernix | 12/31/2014 11:35 AM |
| 5H4N3 | 01/01/2015 7:06 PM |
| 5H4N3 | 01/03/2015 12:18 AM |
| Flxible | 01/03/2015 12:49 AM |
| 5H4N3 | 01/03/2015 2:23 AM |
| 5H4N3 | 01/06/2015 5:13 PM |
| Shaanxi | 01/08/2015 2:04 PM |
| DADS50 | 01/08/2015 2:19 PM |
| Steve_H | 01/08/2015 4:58 PM |
| Shaanxi | 01/09/2015 5:47 PM |
| DADS50 | 01/09/2015 6:49 PM |
| Shaanxi | 01/10/2015 2:08 PM |
| Steve_H | 01/10/2015 10:03 PM |
| Shaanxi | 01/11/2015 11:06 AM |
| Shaanxi | 01/11/2015 7:17 PM |
| Steve_H | 01/11/2015 8:03 PM |
| Shaanxi | 01/12/2015 10:07 AM | |
