It does, thanks! Hey, I updated the photos's and you can see everything better. I failed to mention that fuel seeps out of the throttle shaft. So where do I go about finding the spring(s) needed and is this something a novice should even attempt or do I just break down and try to find a new or reman carb? Its a 7004468 Rochester B carb. I looked at the kit and not sure if it has springs , 7004363 p/n. Suggestions?
Ron - - Dusty53
1954 Chevy 3604
In the Gallery Forum
