0 members (),
170
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,080 Posts1,055,953 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ...leave the hinges hooked up but LOOSE. Close the hood and if it lays down then tighten the bolts from inside the cab, raise the hood and then tighten the two bolts from the outside. Then hook up the hinges and leave them loose.....let the hood weight settle on the springs and then tighten them up. Should do the trick........ | | |
