| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 4 New Guy | | New Guy Joined: Oct 2006 Posts: 4 | I've installed a Chevy 261 engine in my '46 Chevy pickup but the project has taken so long that I no longer can figure out how the throttle linkage should be set up with the rods and butterfly. Does anyone have photos or drawings of how this throttle system should be connected? Thanks | | | | | Joined: Dec 2001 Posts: 14,526 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,526 | Vetteguy, welcome to the Stovebolt group. Best old GMC and Chevy site on the web. The 261 linkage should basically hook up like the 235's in a car. Meaning you should have a "curved" rod going to and thru the toeboard, which hooks to the "swivel" on the side of the block just behind the exhaust pipe. From there should be a fairly straight rod going up from the swivel to the carb.It will be basically the same in your '46.
I'm sure Deve or one of the other guys has a picture but I don't have it marked. I'm sure they will chime in shortly. | | | | | Joined: Oct 2006 Posts: 4 New Guy | | New Guy Joined: Oct 2006 Posts: 4 | My problem is that I'm unable to sort out how the rods from the accelerator to the butterfly swivel and from the butterfly to the carb linkage should be arranged. I'm also running dual Carter/Weber carbs on an Offenhauser manifold but the principle is the same that when I depress the accelerator the motion must pull down on the rod that goes from the butterfly to the carb linkage. If there is a photo or drawing anywhere out there in Stovebolt land, it will be helpful to this "non-engineering" chap. Regards | | |
