1 members (joe apple),
110
Mod | | | Forums66 Topics128,089 Posts1,056,139 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I'm getting ready to install the new window run channels in the doors of my '50, 3604. first let me say that I do not want to use pop rivets, 3m weather strip adhesive or flat head screws to install them. I have a new set of clips from Steele for the ends and up around the window opening. They each have a few triangular pointed tabs that are punched out and raised up about an 1/8 of an inch and perpendicular to the clip. They are the same as the original clips which were punched through the corrugated metal and bent over. Has anyone ever successfully installed these type of clips and if so do you have I'm looking for any suggestions for installing them with out destroying the channel? Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | Pop Rivets LOL!  | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Wha'd I say Wilber???? "first let me say that I do not want to use pop rivets, 3m weather strip adhesive or flat head screws to install them." I know, yur just tryin' ta get my goat, aren't ya! And I also know there are others out there, hiding in the shadows, that are a anal as I am about this stuff, and I’d sure like to hear their stories.
I'm well aware that there are fifty ways to attach your channel. But I don't want a new plan Stan. What I'm trying to figure out is how to do it the correct way, in other words the way the factory did it. Just the purist in me coming out. I've been thinking about machining some Maple blocks that will fit inside the channel and trap the legs to keep them from spreading. That would act as an anvil to drive the barbs through the corrugations. Then I could use something similar to a rivet set to roll them over inside. These materials are so expensive I feel I only have one chance at it and that there isn’t any room to experiment with it. The clips alone are a couple of bucks each not to mention what it cost for the channels. With a dozen clips to install, I think it’s worth figuring it out. Then the next few will be easy. I figured out a way to staple the cat’s whiskers anti-rattle strips to the garnish using the original holes, now I need to get this one nailed down.
I would imagine that the factory had something similar to a stapler that drove the clip through and folded the barb over all in one operation. Denny Graham Sandwich, IL
| | | | | Joined: Jul 2004 Posts: 427 Shop Shark | | Shop Shark Joined: Jul 2004 Posts: 427 | | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | Denny, Did you have any luck with this? I am about to attempt this myself. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Hi Eric. It's been a while so it's a little hazy, but yes, I managed to get them in like the original ones but it was a real pain in the ars. they are very difficult to get thru the channel and there isn't much of the barb sticking thru. I broke the points of the barbs on a lot of them when I tried to bend them over/crimp them. The reproduction clips are not properly heat treated and they break off when you bend them over. I had to cut some of my own with longer barbs from annelid spring steel that were not as hard as the reproductions. The factory had specially designed dies to drive them thru the corrugated channel and bend them over like a staple. Although not authentic, I would recommend attaching them like the other guys have suggested, i.e., pop rivets, or flat head screws. The pop rivets have a large head which will show but small #4 flathead screws will embed themselves in the fibers and almost completely disappear. Some have cemented them but I personally wouldn't use that method. Denny Graham Sandwich, IL
| | | | | Joined: Sep 2010 Posts: 252 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 252 | I used small #4 round head sheet metal screws that disappeared almost completely. | | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | Thanks for the reply. Now when you talk of attaching them with screws or whatnot, are you talking attaching the clips to the channel? or forgoing the clips altogether and just screwing the channel to the door? I found some #6 x1/4 screws that look like they may work to hold the clips on the channel without too much sticking out either side, but not sure how much room I have to play with there. If its just a matter of drilling a few holes and screwing the channel to the door thats an easy one. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | No, just forget the clips and screw the channel to the door, works just fine and no one but you will know the difference.
DG
| | | | | Joined: Dec 2006 Posts: 113 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 113 | thanks Denny. Wouldn't have gotten as far with this old truck as I have without guys like you and several others in this forum. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Ok guys, my turn to do this with my truck. How/where did you place the screws and did you screw the run channel to the guide that is bolted inside the door? | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I used the 3M weatherstrip adhesive in the lower channels. I used 5 screws around the upper frame the first a couple inches up from where it goes down inside the door. Then worked my way around maybe every 5-6 inches or so. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I never was any good at chess, just can't think that many moves ahead. But..I can think one move ahead and that's why the question pops up in my mind concerning the replacement of that run channel down the road sometime. I know many of you are thinking that it will last as long as you have the truck because the original one was in there for 60 years. But chances are that original one let the window rattle for 50 of them years. A decade looked like a long way off when I brought my '50 home in 'O5 and restored the inner workings of the doors, but here we are already, only a year away from the end of that first decade. As I like to do, I spent way to much time on the installation of my run channel and put them back exactly the way they came out, with the clips, some of which I had to make copies of. I've only driven old blushing blue about 10,000 miles so I'm not seeing much wear yet but there is some and I'm planning on driving her for a few more decades, hopefully more that I have been. The use of small sheet metal screws to attach the channel (all the way round)sounds to me like the absolute best way to attach it, if you don't want to go thru the agony that the factory used. Applying glue of any sort to hold them in place not only may make it quite difficult to replace them but it seems it would make a real mess of the paint job in the cleanup.
Just my feeling about the subject, not saying it's for everyone.
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | With myself or the future in mind I wanted an easy repair or access more than I wanted an easy first install... I used small allen head screws like those found holding the metal components of vcr/camcorders and the like together. I chose areas of the frame that were dbl thick metal to drill then marked and drilled the channel and frame tapped them. Many extra steps but I found the threads from sheet metal screws wanted to take the 'fuzzies' with them and bind up.
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Guys: Thanks for the feedback. I have decided screws it is and not adhesive. I always think of what will be involved when I have to take it apart again...either to replace or do it again in the proper sequence. To that end, I avoided "gluing" the glass in the vent window frame and took the time to find the proper .032" glazing tape online. I cannot tell you how easy it was to glaze the vent window with the proper thickness material. Simply slide right on, no pounding and 24 hours later rock solid in place. If someone breaks the glass in the future, it will be easy to replace and I wont mess up the very nice automotive finish black paint I spent carefully getting just right. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | I believe you've made a good choice Dave.
Where did you buy you setting tape from, often the tapes the vendors carry are the wrong thickness. Denny Graham Sandwich, IL
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Denny, where else but Ebay. "Vintique Inc." brand. Ebay You can find the tape in various thicknesses. I used 1/32" for both the window bottom track and the vent windows. The window track was the tightest fitting of the pieces and required minor blows with a rubber mallet to set the piece. The vent windows slide right on..one with a little bit of pressure needed and other was seemingly too loose and I did not have confidence it would stay in place. But, the next day it was locked in place. After oil is added to the tape, it gets very sticky over time. Great stuff...way better than the common vendors are selling (cork). Incidentally, I used ATF (non-synthetic) to activate the tape.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 |
40 Chevy 1/2 ton
| | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Yes, that is most likely the same thing.
On another note, I was installing the vertical riveted on rubber seal for the vent window and noticed the Tech Tip on this subject has it wrong. The rivets should be inserted from the vent window side and the setting tool used inside the glass run channel. The Tech Tip shows it being done opposite. | | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | David -
Thanks for the info on thin setting tape
Not contradicting your opinion, but why do you feel that the rivets should be inserted from the vent side?
I inserted mine from the window side, then followed the Tech Tip. Don't think that I could have set them if they were inserted from the vent side.
- Lonnie
- Lonnie My '54 3104Photos that I have shared on Stovebolt via PhotoBucket are no longer available. Please contact me if you want a photo from an old post. lonniecook [at] aol [dot] com. I sold my '54 3104 12/12/2017, but I still visit Stovebolt. OLD STUFF ... houses, furniture, cars, wine ... I love it all | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | The holes in the run channel are tapered on the run channel side. The taper is designed to engage the "mushroomed" end of the rivet. Also the nice clean (head) part of the rivet should be on the visible side. That is my take on the situation, nothing more. Yes, you have to be more creative with backing drifts, but it is possible.
I should also point out that when separating the vent window from the frame, I drilled out the hinge bracket rivets from the frame (not the pivot rivet). This way, the factory pivot rivet is not disturbed and the bracket can simply be pop-riveted back on the frame and the pop-rivets are not visible after the assembly is reinstalled.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Sounds like something that others might be interested in, any pictures guys, just to fill in the blanks??? Something additional that someone replacing their vent window might be interested in: http://www.pbase.com/dennygraham/vent_windowDenny G
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I came to the same conclusions as DavidF when I did mine. I think the 'creative backing' I used was a small chunk of 3/8" steel plate standing vertically in the vice. Thought I shot pics of that project but can't find any... Still once the channel fuzzies and vent window rubber are installed you can't really see one way or the other on mine.
| | | | | Joined: Oct 2010 Posts: 1,232 'Bolter | | 'Bolter Joined: Oct 2010 Posts: 1,232 | Thanks, David
Makes sense to me
- Lonnie
