5 members (kbenz, Gib70, 52Carl, Otto Skorzeny, Rusty Heaps), 155 guests, and 0 robots.
Topics128,108
Posts1,056,238
Members48,437
Aftermarket hood rod brackets (that hold the hood rod to the cab) are readily available. But how were they originally mounted? Are there individual screws, washers and nuts or a single threaded plate as a backer?
They are held on with a rivet that has a smooth head on the outside of the hood. No backer. Scott
I probably wasn't clear. It is the bracket that sits on the cowl and holds the hood down.
My 37 is like that and is held down by two tapered screws with bolts on the bottom under the cowl......or that's how it was when I got it!
Mine was held in place with screws and nuts ,the screws were fine thread
