7 members (2-Ton, MRMEROTH11, Gdads51, JW51, Shaffer's1950, Southerntruck, 1 invisible), 118 guests, and 1 robot.
Topics128,132
Posts1,056,378
Members48,441
Thinking about updating the old Rochester and wondered if anyone has this carb? I have a failry stock 235 in the 59. Now I know a modern carb will be newer and I would hope an improvement but just wondered what others thought of this setup before I run out and buy it as it isnt cheap. Does it offer power or fuel gain or just be a less leaky hopefully issue free set up? I drive in town and freeway often if that helps.
I'm running Langdon's H-Ws and have for several years zero leaks and truck runs great. If you compare his prices to retail auto parts they are really good plus he has the air cleaners etc. Also Tom's linkage is bullet proof, very good quality.
1946 1/2-Ton Chevy
Josh,
Just a quick note. The 32/36 that Tom sells is a Weber DGEV (according to the catalog). Its a bigger carb than the Carter-Weber that he also sells.
Tom no longer sells the Holley-Weber which was similar in size to the Weber DGEV.
regards,
Leon
Thanks guys! Leon I gather? And please bare with me as I'm learning about all e carb options that this new carter would be an improvement over my current set up? Or should I hunt down a holley-weber if its a nicer carb if I'm able. Just don't feel I want to go with dual carbs so I'm trying to figure out the best option on a single. It seems easy till you look and goodness on these 235's everyone has a different thought on the carb! Lol. And again thanks guys.
I have a single h/w from Langdons on my 261. Been on for 5 yrs. never a problem, gets good milage just a little flat in midrange. I have a cam from howards (m4f) and fenton headers.
Tommy
59 apache 1/2t
261 short stepside
ODSS President
ODSS President
I had one H-W on a daily driver only vehicle (from Tom) and it ran great, started to leak after about 7 years and I peeled off one C-W that I had mounted on a dual intake to replace. Ran great. Proceeded to then go with a dual C-W set up runs great.
The single H-W only needed a gasket set, probably 10% alcohol related fuel as the culprit, but with my dd I did the easy thing and wanted to see how the single C-W ran.
Cosmo
~ Cosmo
1949 Chevy Half Ton
Great! Ok then I have my sites set on one then. Thanks guys!
