2 members (klhansen, TS3600),
131
Mod | | | Forums66 Topics128,166 Posts1,057,012 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 31 | Hey,
I have purchased a new grille for my 1949 4400 Chev but they don't come with Vertical Grille Supports. Does any have a set that I can buy?
These parts are impossible to find in Australia.
Shane | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Was this one of the reproduction grilles available from Parts vendors ? If so, it won't fit your Big Bolt as is. | | | | | Joined: Jun 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 31 | Spanky,
This is the one, its listed for 1 1/2 ton and 2 ton.
http://www.oldchevytrucks.com/cart/product.asp?prodid=FP547&i=9923|||||
Shane | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | | | | | | Joined: Apr 2004 Posts: 5,091 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,091 |
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"Success comes in 'cans' ..." | | | | | Joined: Dec 2002 Posts: 2,549 'Bolter | | 'Bolter Joined: Dec 2002 Posts: 2,549 | Thanks Peg. I didn't know JC had these available. Can you not use the verticals from your original grille, or did your truck not have a grille ? You'll definitely need the vertical supports from a big truck grille. they will be taller. | | | | | Joined: Jun 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 31 | Yeah They are the only one i can find. I have got hold of them and they have some second hand ones about $150 shipped to australia so I have gone with those thanks.
Shane | | | | | Joined: Apr 2010 Posts: 474 Shop Shark | | Shop Shark Joined: Apr 2010 Posts: 474 | I didnt know they had them either! 650.00 Time to call JIM.
| | | | | Joined: Jun 2012 Posts: 31 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 31 | Tell them the pest from the west (of australia  ) told you haha they might discount my supports. Shane | | | | | Joined: Jan 2010 Posts: 120 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 120 | I have my 47 1.5 ton grille in bits right now. I bought that same grille set but bare steel. Its a bit rough but fixes up OK ready for chroming. The one I received is made in Argentina. The bars on the big bolts are two inch high and on the smaller trucks, one and three quarter inch. I think the lengths are the same or close enough. I can measure anything you want if you need a cross check. In I have the original grille here. Also I recommend a grille fastener kit, they have a load of bespoke fasteners.
'47 Canadian RHD 1.5 ton truck
