BUSY BOLTERS Are you one? The Shop Area
| | Click on image for the lowdown.
5 members (VEW, GMCJammer51, 3 invisible),
571
robot. | Key: Admin,
Mod | | Forums66 Topics126,777 Posts1,039,270 Members48,100 | Most Online2,175 Jul 21st, 2025 | | | Joined: Jun 2012 Posts: 31 Wrench Fetcher | Wrench Fetcher Joined: Jun 2012 Posts: 31 | Hey,
I have purchased a new grille for my 1949 4400 Chev but they don't come with Vertical Grille Supports. Does any have a set that I can buy?
These parts are impossible to find in Australia.
Shane | | | | Joined: Dec 2002 Posts: 2,538 'Bolter | 'Bolter Joined: Dec 2002 Posts: 2,538 | Was this one of the reproduction grilles available from Parts vendors ? If so, it won't fit your Big Bolt as is. | | | | Joined: Jun 2012 Posts: 31 Wrench Fetcher | Wrench Fetcher Joined: Jun 2012 Posts: 31 | Spanky,
This is the one, its listed for 1 1/2 ton and 2 ton.
http://www.oldchevytrucks.com/cart/product.asp?prodid=FP547&i=9923|||||
Shane | | | | Joined: Dec 2002 Posts: 2,538 'Bolter | 'Bolter Joined: Dec 2002 Posts: 2,538 | | | | | Joined: Apr 2004 Posts: 5,139 Authorized Pest | Authorized Pest Joined: Apr 2004 Posts: 5,139 |
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery || In the Gallery Forum"I didn't see this one coming. I don't see much of anything coming. :-O" | | | | Joined: Dec 2002 Posts: 2,538 'Bolter | 'Bolter Joined: Dec 2002 Posts: 2,538 | Thanks Peg. I didn't know JC had these available. Can you not use the verticals from your original grille, or did your truck not have a grille ? You'll definitely need the vertical supports from a big truck grille. they will be taller. | | | | Joined: Jun 2012 Posts: 31 Wrench Fetcher | Wrench Fetcher Joined: Jun 2012 Posts: 31 | Yeah They are the only one i can find. I have got hold of them and they have some second hand ones about $150 shipped to australia so I have gone with those thanks.
Shane | | | | Joined: Apr 2010 Posts: 474 Shop Shark | Shop Shark Joined: Apr 2010 Posts: 474 | I didnt know they had them either! 650.00 Time to call JIM.
| | | | Joined: Jun 2012 Posts: 31 Wrench Fetcher | Wrench Fetcher Joined: Jun 2012 Posts: 31 | Tell them the pest from the west (of australia  ) told you haha they might discount my supports. Shane | | | | Joined: Jan 2010 Posts: 120 Shop Shark | Shop Shark Joined: Jan 2010 Posts: 120 | I have my 47 1.5 ton grille in bits right now. I bought that same grille set but bare steel. Its a bit rough but fixes up OK ready for chroming. The one I received is made in Argentina. The bars on the big bolts are two inch high and on the smaller trucks, one and three quarter inch. I think the lengths are the same or close enough. I can measure anything you want if you need a cross check. In I have the original grille here. Also I recommend a grille fastener kit, they have a load of bespoke fasteners.
'47 Canadian RHD 1.5 ton truck
