3 members (1955 1 Series, Gdads51, 1 invisible),
75
Mod | | | Forums66 Topics128,037 Posts1,055,582 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you'll have to elaborate koop, I see an electric wiper motor, which has a [missing] line for the windshield washer, but there won't be any choke connections there
Bill | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | Yep, all I see is a wiper-washer motor. | | | | | Joined: Jan 2014 Posts: 16 New Guy | | New Guy Joined: Jan 2014 Posts: 16 | OK, looks like someone tapped into the wiper washer wiring for power for the electric choke... neither of which are currently working. Thanks guys.
I have my work cut out for me under the dash. I found another item attached to the steering column that I assume is the brake light switch. Some of the wires are spliced, some are dead ended... I am torn between replacing the whole wiring harness or redoing the one that is in there. Either way, I think I will remove the current one and go over it really good before I reinstall it. There is, however, a modern fuse block, which is nice.
One more thing is an item that looks like a relay mounted to the firewall in the vicinity of the clutch pedal that currently has no wires attached to it. Anyone want to hazard a guess on that one? This could be the beginning to a fun little game... identify the part! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | need a picture, could be anything from a flasher to an add-on headlight relay .... and the brake light switch wouldn't be on the column, maybe a reverse light switch if it's a column shift
a shop manual could be helpful, they're available at the vendors
Bill | | | | | Joined: Feb 2004 Posts: 29,760 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,760 | The electric choke needs to be powered by an oil pressure switch so it only gets voltage when the engine is running. Otherwise, if you start the engine, go back inside for another cup of coffee while it warms up, then it runs awhile and stalls, the choke will continue to be heated and release itself before you get back to start again. Then it's difficult to start the cold engine with no choke. Jerry
| | | | | Joined: Jan 2014 Posts: 16 New Guy | | New Guy Joined: Jan 2014 Posts: 16 | I've started to realize that all the wiring under the dash is a mess! I pulled it all apart tn. I'm going to get a shop manual and wire it all proper. One of the previous owners made a mess of it.
Thanks for that tip Lincoln. | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | If the wires are that bad I'd recommend a new harness.
