1 members (klhansen), 147 guests, and 0 robots.
Topics128,162
Posts1,056,939
Members48,458
Hi all,
I am pulling the rear leaf springs on my pickup to clean and add spring liners. The rear shackle came loose easily enough as did the u-bolts. The problem is the floating pin at the front of the rear spring won't come out. I removed the locking bolt and the floating pin slides back and forth but contacts the frame on the inside and the running board on the outside. Am I missing something or do I need to remove the running board to get the pin out?
Yes, on a '56 the running board must be removed.
I guess this is why someone modified the spring attachment on my '55? [URL=http://s1348.photobucket.com/user/capnduane/media/55Chev413_zps9e082ec0.jpg.html]Photobucket[/url]
Thanks Cletis. I will pull them off.
Wow, that's quite a frame notch Cap'n!
