1 members (Hotrod Lincoln),
92
Mod | | | Forums66 Topics128,132 Posts1,056,729 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Hi all,
I am pulling the rear leaf springs on my pickup to clean and add spring liners. The rear shackle came loose easily enough as did the u-bolts. The problem is the floating pin at the front of the rear spring won't come out. I removed the locking bolt and the floating pin slides back and forth but contacts the frame on the inside and the running board on the outside. Am I missing something or do I need to remove the running board to get the pin out? | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | Yes, on a '56 the running board must be removed. | | | | | Joined: Aug 2013 Posts: 217 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 217 | I guess this is why someone modified the spring attachment on my '55? [URL=http://s1348.photobucket.com/user/capnduane/media/55Chev413_zps9e082ec0.jpg.html]Photobucket[/url]
| | | | | Joined: May 2005 Posts: 85 Shop Shark | | Shop Shark Joined: May 2005 Posts: 85 | Thanks Cletis. I will pull them off.
Wow, that's quite a frame notch Cap'n! | | |
