| | | Forums66 Topics128,267 Posts1,058,386 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | WHAT HOLES ARE SUPPOSE TO BE THERE AND WHAT HOLES ARE SUPPOSE TO BE WELDED ? 54 FIREWALL | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | That looks like an unmolested firewall. I don't think you have any extra holes if you are talking keeping it original.
Bruce
| | | | | Joined: Mar 2007 Posts: 4,217 Moderator | | Moderator Joined: Mar 2007 Posts: 4,217 | I agree. Some of the holes may not be used, such as the one for the heater or the heater valve. There is a cover plate available for the heater motor hole. | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | There is a page in the 1954 Factory Assembly Manual that outlines all holes and their purpose I believe? Don't have mine handy but I know it is in there. | | | | | Joined: Oct 2005 Posts: 4,263 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,263 | I think the two you circled on the right are for the Harrison heater studs. The three on the engine hump, under the cowl drain, shouldn't be there. | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | i was looking at some picture when i first got my truck . this is how it looked FIREWALL 1 FIREWALL 2 FIREWALL 3 FIREWALL 4 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | big_dan_1950,
Your photos confirm that you had a non-1954-GM-truck heater. The heater valve is not original, and the GM heater-unit that used a valve would have mounted differently to the firewall.
What heater will you be putting in the truck? If you will use the heater you show, you will need those holes. | | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | it came with the correct heater ,but not with the correct vale . looks like they made it . heater 1 heater 2 | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | big_dan_1950,
Sorry about my error on the heater. The holes in the cowl looked odd. You do have a 53-55 deluxe heater.
| | | | | Joined: Apr 2009 Posts: 121 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 121 | this is what i think should be welded . does this look right ? i dont think the hole with the ? mark is suppose to be there . they had it pluged with a rubber grommet . oops i forgot to mark some holes . ill mark them next time firewall holes firewall mystery hole mystery hole plug | | |
