4 members (Gdads51, Chris_Welch, texas46, 1 invisible), 144 guests, and 3 robots.
Topics128,267
Posts1,058,386
Members48,485
#996951 01/05/2014 4:34 AM
WHAT HOLES ARE SUPPOSE TO BE THERE AND WHAT HOLES ARE SUPPOSE TO BE WELDED ?
54 FIREWALL
That looks like an unmolested firewall. I don't think you have any extra holes if you are talking keeping it original.
Bruce
My Trucks
Stuff I Collect
Leo Offline
Moderator
Moderator
I agree. Some of the holes may not be used, such as the one for the heater or the heater valve. There is a cover plate available for the heater motor hole.
There is a page in the 1954 Factory Assembly Manual that outlines all holes and their purpose I believe? Don't have mine handy but I know it is in there.
Haunting the SBP since 2001
Driver side looks good.
The passenger side around the heater motor hole and heater control valve hole looks like it will need some work.
http://img.claspics.com/vcd7kvr/hq2xh191/1388964304-809.jpg_m.jpg?1388964309
I think the two you circled on the right are for the Harrison heater studs. The three on the engine hump, under the cowl drain, shouldn't be there.
Here is my '54s unmolested firewall, it looks like yours might have a few extra holes around the heater and whatever those dents are in the engine hump.
http://i190.photobucket.com/albums/z264/tony6461/9c29b503.jpg
i was looking at some picture when i first got my truck . this is how it looked
FIREWALL 1
FIREWALL 2
FIREWALL 3
FIREWALL 4
big_dan_1950,
Your photos confirm that you had a non-1954-GM-truck heater. The heater valve is not original, and the GM heater-unit that used a valve would have mounted differently to the firewall.
What heater will you be putting in the truck? If you will use the heater you show, you will need those holes.
it came with the correct heater ,but not with the correct vale . looks like they made it .
heater 1
heater 2
big_dan_1950,
Sorry about my error on the heater. The holes in the cowl looked odd. You do have a 53-55 deluxe heater.
this is what i think should be welded . does this look right ? i dont think the hole with the ? mark is suppose to be there . they had it pluged with a rubber grommet . oops i forgot to mark some holes . ill mark them next time
firewall holes
firewall mystery hole
mystery hole plug
