0 members (),
124
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,157 Posts1,056,876 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2009 Posts: 123 'Bolter | | 'Bolter Joined: Sep 2009 Posts: 123 | I need to replace my heater core. I have a 53 Chev. 3100 with a heater like this http://lh6.googleusercontent.com/-F...AAAAnI/-mOHedBRnuo/s1024-no/IMG_9424.JPGHas anyone purchased one new for this heater and, if so, where. Some of the suppliers I have tried show the core in their catalog but are out of stock. According to Dads50[whose photo this is, Thanks]it is a H-02-47 heater. | | | | | Joined: Aug 2001 Posts: 1,300 'Bolter | | 'Bolter Joined: Aug 2001 Posts: 1,300 | That heater without the vertical vent door next to the inner cowl panel, is the one that the aftermarket has addressed in reproduction heater cores. Jim Carter, Classic parts, Brother's, LMC, and others should have a new one for you. | | | | | Joined: Mar 2011 Posts: 153 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 153 | I have had good luck having several heater cores redone with the original tanks and new cores by the same local shop that re-cores my radiators. That way, I know it's all top-notch USA rather than some Asian import. Spike Radiator, Denver,CO (303) 762-7522
1946 Chevy pickup, 1948 Chevy suburban, 1950 Chevy pickup, 1952 GMC pickup, 1957 Chevy pickup, 1939 Chevy pickup
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Joe, I don't have the link but I understand that there is now someone making the one you need.....Maybe someone will chime in that knows more about it. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Chip might be thinking of this threadBill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Red, your right. I seen it when Peggy posted it..... BUT I do remember a post for another place. Not sure what years were covered but there was one. I'm busy as a cat on a tin roof right now but if I get snowed in maybe I have it in my archives somewhere and I'll see if I can find it. Thanks for posting about BrassWorks, which is one of the latest added links. | | |
