1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#99669 03/05/2007 4:39 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | LeeA,
Isn't that the resistor for the heater fan motor. I thought those were mounted inside the ducting which cooled them when running the fan motor at one of the low speeds. This is just a guess..would this be too old for a Chevrolet dealer to order.
Stuart | | |
#99671 03/05/2007 5:03 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | LeeA,
I'm not familiar with these rigs, but I think the resistor is for the fan motor. The other items in the picture on the site you linked are probably associated with the A/C. The poor old resistor just happened to be in the picture because that's where it lives, it's an innocent bystander.
Red58 is an expert on these trucks, maybe he will see this and shed some light on it.
Stuart | | |
#99672 03/05/2007 8:24 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | no expert on AC fer sure! but check blower resistors here - 3 different models listed - look similar, might be what you need Bill | | |
#99673 03/05/2007 2:32 PM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | HAC-44(same as 67-72 w/AC) is what I put on mine, works fine but I had to fine tune the fitting, one mounting hole was a little bit off. Brian | | |
#99674 03/05/2007 4:40 PM | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | Thanks everybody, looks like I'll be buying the HAC-44 and modifying the mounting hole... no big deal.
Lee | | |
#99675 03/06/2007 12:36 AM | Joined: Oct 2006 Posts: 128 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2006 Posts: 128 | | | |
#99676 03/06/2007 12:49 AM | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | but American Classic is a Stovebolt sponser, and a couple bucks cheaper to boot Bill | | |
#99677 03/06/2007 12:52 AM | Joined: Jul 2004 Posts: 5,708 'Bolter | | 'Bolter Joined: Jul 2004 Posts: 5,708 | Before this thread goes bye bye, I need to make it clear in my mind that this resistor is for the fan motor and has nothing to do with the A/C...is this correct.
Stuart | | |
#99678 03/06/2007 3:38 AM | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Well Stuart yes & no-one blower runs both the A/C & heat, but it has no effect on the compressor operation. Brian | | |
#99679 03/06/2007 3:42 AM | Joined: Oct 2003 Posts: 5,152 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Oct 2003 Posts: 5,152 | Stuart the fan is used by the AC so its hard to say it has nothing to do with the AC. However vehicles without AC have the same type of resister block for fan speed control.
Think of it as a interior circulation fan speed control device and vent, heat or AC all use it.
1955 1st GMC Suburban | 1954 GMC 250 trailer puller project | 1954 GMC 250 Hydra-Matic | 1954 Chevy 3100 . 1947 Chevy COE | and more... It's true. I really don't do anything but browse the Internet looking for trouble... | | |
