2 members (Otto Skorzeny, dt235sd), 122 guests, and 1 robot.
Topics128,052
Posts1,055,719
Any idea where I can find a new one of these? It's the resistor on the air conditioning evaporator box in my '65 C-10. [img]http://laanderud.com/65chevy/misc/AC%20Part%20Needed.jpg[/img]
[img]http://laanderud.com/65chevy/misc/AC%20Top.jpg[/img]
Thanks.
Lee
1965 Chevy C-10 Gallery page
My Chevy truck pages more info and pictures!
1961 Studebaker Hawk
1962 Shasta 16' AirFlyte Travel Trailer
1941 Case Model S tractor
LeeA,
Isn't that the resistor for the heater fan motor. I thought those were mounted inside the ducting which cooled them when running the fan motor at one of the low speeds. This is just a guess..would this be too old for a Chevrolet dealer to order.
Stuart
Not sure, here's what I found on the other forum:
http://www.chevytalk.org/fusionbb/showtopic.php?tid/152516/
Thanks.
Lee
LeeA,
I'm not familiar with these rigs, but I think the resistor is for the fan motor. The other items in the picture on the site you linked are probably associated with the A/C. The poor old resistor just happened to be in the picture because that's where it lives, it's an innocent bystander.
Red58 is an expert on these trucks, maybe he will see this and shed some light on it.
Stuart
no expert on AC fer sure!
but check blower resistors here - 3 different models listed - look similar, might be what you need
HAC-44(same as 67-72 w/AC) is what I put on mine, works fine but I had to fine tune the fitting, one mounting hole was a little bit off. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Thanks everybody, looks like I'll be buying the HAC-44 and modifying the mounting hole... no big deal.
Lee
Looks like LMC has the correct version:
http://www.lmctruck.com/icatalog/cbe/0058.asp
Lee
but American Classic is a Stovebolt sponser, and a couple bucks cheaper to boot grin
Before this thread goes bye bye, I need to make it clear in my mind that this resistor is for the fan motor and has nothing to do with the A/C...is this correct.
Stuart
Well Stuart yes & no-one blower runs both the A/C & heat, but it has no effect on the compressor operation. Brian
Stuart the fan is used by the AC so its hard to say it has nothing to do with the AC. However vehicles without AC have the same type of resister block for fan speed control.
Think of it as a interior circulation fan speed control device and vent, heat or AC all use it.
