1 members (Hotrod Lincoln),
60
0
Mod | | | Forums66 Topics128,050 Posts1,055,641 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2012 Posts: 9 New Guy | | New Guy Joined: Mar 2012 Posts: 9 | Need some help diagnosing a starting problem on my 1963 longbed. 350 SBC with RV cam, SM420 and an accel HEI distributor (coil has red and yellow wires). It normally starts and runs fine. Every once and while it will not start. Engine turns over strong, but no spark at the plugs. If I leave it sit for an hour or two or longer, it starts right up again.
The battery measures 12.68 volts. That's a bit low and I've noticed that the voltmeter drops to around 8.5 volts when cranking...is that enough to fire off the HEI? Is the battery the culprit or could the coil just randomly stop working and then start again? It has a new 140amp internally regulated alternator. Anything I should be checking there?
It has a full american autowire rewire that I just put in about 3 months ago. Not sure if the problem existed before that though because it was the first thing I did when I got the truck.
sorry for the lengthy set of questions...hoping that the collective wisdom will point me in the right direction
thanks, Greg | | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Where is the coil mounted?
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | did you replace the resistor wire from the ignition switch to the coil. should be replaced with a non resisted wire so that it gets a full 12 volts when either starting or running. with a points ign it had 12v on start 9v on run ron | | | | | Joined: Mar 2012 Posts: 9 New Guy | | New Guy Joined: Mar 2012 Posts: 9 | Hei in the cap. Not external
thanks Greg
| | | | | Joined: Mar 2012 Posts: 9 New Guy | | New Guy Joined: Mar 2012 Posts: 9 | thanks for the response. It's an HEI so the coil is in the cap. I replaced the 12 volt wire when I replaced all the wire and fusebox in the truck.
thanks, Greg
| | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | thanks for the response. It's an HEI so the coil is in the cap. I replaced the 12 volt wire when I replaced all the wire and fusebox in the truck.
thanks, Greg I know that it is an hei because you said so before. you also installed a wiring kit; see i can read.was that wiring kit for a points ign or was it for an hei installation. they told you which wire to use right. didn't you also say that it was reading 9 volts through there on start so it must also must be running 9 volts while it is running. you may have wired it for an hei which is why it is starting and running on 9 volts as perhaps that wire is a resistor wire. I don't care where the coil is mounted, it is still an hei ron | | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | The wiring kits that I have seen don't include a resistor wire for the coil but many have undersized wire if an HEI is used. I believe that GM recommends a #10 wire for an HEI, most of the wiring kits provide a #16 wire. That may contribute to your problem but I don't believe it would cause a 3 volt drop. Fred
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | I have the same kit on my 65. I run all msd ignition and it works fine. I know ive had the coil get too hot and cause a non start issue. I moved my ignition box from the fender to the glove box. and ive mounted the coil on the firewall by the brake master cylinder. what kind of hei are you running?
| | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | Load Test the battery, 8.3 is low for any elecronic ignition, how old is the battery? Next time it won,t start try a booster battery or jumper cables, that should help narrowing it down.
You Learn more Listening than Talking
| | | | | Joined: Mar 2004 Posts: 3,068 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 3,068 | HEI module going intermittent with heat??? Scott | | | | | Joined: Sep 2010 Posts: 698 Shop Shark | | Shop Shark Joined: Sep 2010 Posts: 698 | Check your ignition switch. As stated earlier it switches to 12 volts during cranking and 9v during running - but with a bad / intermitant ignition switch you could be getting 0 volts during cranking and 9 with the key in the run position. So you need to check voltage at the distributor DURING the cranking when it is not starting - cause if it's intermitant like you say, you'll only find it when it's not working.
My Fleet: 19411953195919651966 1953 Willy's Pickup John Vegetarian- old Indian word for bad hunter
| | | | | Joined: Mar 2012 Posts: 9 New Guy | | New Guy Joined: Mar 2012 Posts: 9 | Folks, thanks for all the ideas. Since the switch tested good, it seems either the coil or the module was the culprit. Replacing both would have cost more than a new, from summit racing, distributor so I went that route. No problems since.
thanks again Greg | | |
