4 members (MickeyP, Ole49GMC, Tronman, Peggy M), 83 guests, and 1 robot.
Topics128,043
Posts1,055,610
Need some help diagnosing a starting problem on my 1963 longbed. 350 SBC with RV cam, SM420 and an accel HEI distributor (coil has red and yellow wires). It normally starts and runs fine. Every once and while it will not start. Engine turns over strong, but no spark at the plugs. If I leave it sit for an hour or two or longer, it starts right up again.
The battery measures 12.68 volts. That's a bit low and I've noticed that the voltmeter drops to around 8.5 volts when cranking...is that enough to fire off the HEI? Is the battery the culprit or could the coil just randomly stop working and then start again? It has a new 140amp internally regulated alternator. Anything I should be checking there?
It has a full american autowire rewire that I just put in about 3 months ago. Not sure if the problem existed before that though because it was the first thing I did when I got the truck.
sorry for the lengthy set of questions...hoping that the collective wisdom will point me in the right direction
thanks,
Greg
Where is the coil mounted?
did you replace the resistor wire from the ignition switch to the coil. should be replaced with a non resisted wire so that it gets a full 12 volts when either starting or running. with a points ign it had 12v on start 9v on run
ron
Hei in the cap. Not external
thanks
Greg
thanks for the response. It's an HEI so the coil is in the cap. I replaced the 12 volt wire when I replaced all the wire and fusebox in the truck.
thanks,
Greg
thanks,
Greg
I know that it is an hei because you said so before. you also installed a wiring kit; see i can read.was that wiring kit for a points ign or was it for an hei installation. they told you which wire to use right. didn't you also say that it was reading 9 volts through there on start so it must also must be running 9 volts while it is running. you may have wired it for an hei which is why it is starting and running on 9 volts as perhaps that wire is a resistor wire. I don't care where the coil is mounted, it is still an hei
ron
The wiring kits that I have seen don't include a resistor wire for the coil but many have undersized wire if an HEI is used. I believe that GM recommends a #10 wire for an HEI, most of the wiring kits provide a #16 wire. That may contribute to your problem but I don't believe it would cause a 3 volt drop.
Fred
I have the same kit on my 65. I run all msd ignition and it works fine. I know ive had the coil get too hot and cause a non start issue. I moved my ignition box from the fender to the glove box. and ive mounted the coil on the firewall by the brake master cylinder. what kind of hei are you running?
Load Test the battery, 8.3 is low for any elecronic ignition, how old is the battery? Next time it won,t start try a booster battery or jumper cables, that should help narrowing it down.
You Learn more Listening than Talking
HEI module going intermittent with heat???
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Check your ignition switch. As stated earlier it switches to 12 volts during cranking and 9v during running - but with a bad / intermitant ignition switch you could be getting 0 volts during cranking and 9 with the key in the run position. So you need to check voltage at the distributor DURING the cranking when it is not starting - cause if it's intermitant like you say, you'll only find it when it's not working.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Folks, thanks for all the ideas. Since the switch tested good, it seems either the coil or the module was the culprit. Replacing both would have cost more than a new, from summit racing, distributor so I went that route. No problems since.
thanks again
Greg
