| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | My truck is a 1/2 ton, 1953. I just got my transmissions swapped out, hooked everything back up, put the shifter back in. I have the truck on the hoist, just off the floor. I started the engine and am going through the gears. It shifts into all the gears fine (not sure about reverse) but when I let the clutch up, it stalls out as if it is stuck in 2 gears. I picked the transmission up at Jim Carter's last Sept, they checked it over, I think the problem is a minor one. Any help is much appreciated. | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Release the emergency brake. If the wheels are off the ground with no resistance, the rear brakes must be on/screwed up. Or rear end/driveshaft locked. Turn the rear wheels by hand one at a time with engine off and trans in neutral to check movement of driveline. If it is still stuck, push in clutch. If that works, its a clutch component bind. Clutch plate/spring fingers,fork, pilot bushing or throw out bearing could be binding somehow. Never heard of tranny guts getting that screwed up after being checked over and lubed.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Problem solved, the shifter fork was not aligned correctly. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | These guys with the heated cozy shops with lifts can do anything they want regardless of our winter weather! Good luck with your new tranny, Leo. | | | | | Joined: Nov 2012 Posts: 441 Stovebolt Photo Moderator | | Stovebolt Photo Moderator Joined: Nov 2012 Posts: 441 | Leo,
What are you going to do with that old transmission? I thought it was kind of quiet once the fluid levels were topped out.
Glad to hear from you.
Amtrakjoe, I sat next to that transmission coming back from Jim Carter's ....... 1947 - 3800 dually known as "Deadwrench"Link to a few photosIn this world there are givers and takers. The takers eat well, the givers sleep well. | | |
