6 members (J Lucas, Hotrod Lincoln, Jon G, Otto Skorzeny, MikeE, ShopRag), 83 guests, and 1 robot.
Topics128,036
Posts1,055,450
Members48,422
#996355 01/03/2014 12:29 AM
Leo
Offline
Moderator
Moderator
My truck is a 1/2 ton, 1953. I just got my transmissions swapped out, hooked everything back up, put the shifter back in. I have the truck on the hoist, just off the floor. I started the engine and am going through the gears. It shifts into all the gears fine (not sure about reverse) but when I let the clutch up, it stalls out as if it is stuck in 2 gears. I picked the transmission up at Jim Carter's last Sept, they checked it over, I think the problem is a minor one. Any help is much appreciated.
Leo #996361 01/03/2014 1:09 AM
Sir Searchalot
Sir Searchalot
Release the emergency brake. smile If the wheels are off the ground with no resistance, the rear brakes must be on/screwed up. Or rear end/driveshaft locked. Turn the rear wheels by hand one at a time with engine off and trans in neutral to check movement of driveline. If it is still stuck, push in clutch. If that works, its a clutch component bind. Clutch plate/spring fingers,fork, pilot bushing or throw out bearing could be binding somehow. Never heard of tranny guts getting that screwed up after being checked over and lubed.
Leo #996416 01/03/2014 4:57 AM
Leo
Offline
Moderator
Moderator
Problem solved, the shifter fork was not aligned correctly.
Leo #996647 01/04/2014 2:55 AM
These guys with the heated cozy shops with lifts can do anything they want regardless of our winter weather! Good luck with your new tranny, Leo.
1951 1 Ton Completed
Leo #996649 01/04/2014 3:19 AM
Stovebolt Photo Moderator
Leo,
What are you going to do with that old transmission? I thought it was kind of quiet once the fluid levels were topped out.
Glad to hear from you.
Amtrakjoe, I sat next to that transmission coming back from Jim Carter's .......
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
