| | | Forums66 Topics128,195 Posts1,057,369 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 34 | Is the cab on a '46 1/2 ton the same size as a 1-1/2 ton cab? I know the fenders are different, but are the grill, dash, seats and interior panels inter-changeable? Will 1/2 ton front fenders bolt up properly to a 1-1/2 ton cab and vice versa?
Grease magnet
| | | | | Joined: Nov 2005 Posts: 6,101 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,101 | Hy 41flatbed, the cabs for the conventional trucks you are asking about are all the same, all the 41-46 grilles for conventional trucks are the same, hope that helps
| | | | | Joined: Mar 2011 Posts: 667 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 667 | Near as I can tell, all the front end body parts are the same except for the fenders. They are different. I believe the 1/2T & 3/4T are the same, but the 1T & 2T each have progressively larger fenders. That said, they can be swapped as a few folks have put the larger fenders on smaller trucks.
If anyone else has better info, please share it. | | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | The 1/2 and 3/4 ton trucks are exactly the same with the exception of bed length. The larger trucks have larger fenders, but you can swap either way. Not sure if the running boards are different. | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | My experience with 1/2 and 3/4 ton front fenders is that while they may look the same there is a different contour where it bolts to the running board. You could make it work but slightly different. | | | | | Joined: Jul 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 34 | Thanks 3B. I have a very nice grill that came from a cab that has big fenders, but it's on a 3/4 ton frame. I'm attempting to put everything on a 1/2 ton frame that has a good 216 engine, transmission and working brakes. My big problem will be finding steel 1/2 ton fenders (front). Appreciate your help.
Grease magnet
| | | | | Joined: Jul 2013 Posts: 34 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2013 Posts: 34 | Thanks to all for your help. I can move on with other 1/2 ton items. i.e. fenders.
Grease magnet
