3 members (baldeagle, D B Cooper, 1 invisible),
101
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,094 Posts1,056,064 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | I got the 54' 235 engine running the other day and noticed the press-in oil galley plug leaks. This is located in the front of the engine next to the generator. I ran the truck for a 20-minute break-in so it was good and warm and it still didn't want to seal.
I just now replaced it with another plug and it too leaks. The sleeve it presses into looks to be in good shape with no apparent grooves or scratches in it. My question is, should I try it again and coat the thing with some blue lock-tite, or possibly get a bigger size. The one that originally came out was 19/32.
Thanks for the advice.
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Probably wouldn't hurt to coat it with a sealer (permatex) or similar before installing.
John | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Later 235's are threaded for pipe plugs. Probably hard to tap with the engine together and in place.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Thanks for the input guys. I will give it one more try and if it doesn't work out I will thread it.
| | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | Indian Head sealer works well here. It is similar in smell and non-hardening properties as permatex 2. It is a liquid and comes in a brown bottle that has a brush built into the cap.
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | wow, the PC police still allow that to be marketed under that name? That is what my dad always used, I haven't been able to find it recently, I thought they removed it because of the name. | | | | | Joined: Mar 2010 Posts: 10,279 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,279 | wow, the PC police still allow that to be marketed under that name? That is what my dad always used, I haven't been able to find it recently, I thought they removed it because of the name. You need to rent a moving van and move away from there, Jed. Its worse than California and they ain't got no Injun Head. I found some at NAPA.
| | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Tried it again....this time with permatex around the plug before I put it in. Let it set up for 24 hours, then smeared some silicone around the edge of the plug where it meets the block. Let that sit another 24 before starting. Still leaks.
My concern here is that it seems there is a sleeve in the block that this plug goes into so I'm not confident in tapping this properly without leaving metal shavings. The hole in the block that presumably leads from this galley back to the pan is almost directly behind this plug so the shavings make me nervous. I will do it if I have to but would rather try the plug more time.
Any other advice?
Thanks All
| | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Update...4th attempt worked. Used a coat of red locktite in the block first and allowed it to set a bit, then coated the plug itself with more red locktight before installing. That plug will never see the light of day again.
| | | | | Joined: Feb 2011 Posts: 1,362 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,362 | I just read this and locktite was my first choice.
And not to pick on, but to educate. Galley :1 a low flat ship with sails and oars. 2 a kitchen in a ship or aircraft.
Proper name GALLERY : a passage
Just type define oil galley into google, you will find it is a misspelling.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Thanks for the clarification Truckrolet.
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Been saying it and hearing it wrong for 50 years. You learn something new every day! Thanks Truckrolet.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Galley is surely the wrong word, but, oddly, the Americam Engine Rebuilders Association also has it wrong . Thanks, Truckrolet, I also had restated incorrectly what I had previously been told. Google "oil gallery" to see how pervasive this misuse is. | | |
