3 members (dt235sd, Bucker, UtahYork), 160 guests, and 4 robots.
Topics128,196
Posts1,057,390
Members48,471
As I near having everything I need to complete my chassis I am down to the drive shaft, exhaust and gas tank.
I'm running a T5 behind a 235. What to do for a driveshaft? Am I lucky enough that something from another vehicle might fit? I thought I read something about a shaft from a a Dodge van but can't find it now.
On my 1954 3100 I used the driveshaft from a Chevy Astro van. Used a combination U-joint to connect it to the rear end from 1962 C10. Didn't have to cut or modify the driveshaft.
What year Astro?
I just checked my notes from when I did the conversion and I have written down "early 90's'.
Was it a 2 part shaft?
It's a one piece. The front yoke that came on it slipped right into the T-5.
1955-59 PU are the correct length.
My Blog
Yeah but hard to find.
So doing a parts search, when it lists the front and the rear the front must be the yoke and the rear the actual shaft?
Mine was out of a 1999 astro van RWD. Exact same measurement as this one for sale right now. Bought mine from here also. Check you measurements.
http://www.ebay.com/itm/1994-Chevy-Astro-Van-Rear-Drive-Shaft-49-3-4-Center-U-U-Joint-26036048-/221258002678?pt=Motors_Car_Truck_Parts_Accessories&fits=Model%3AAstro&hash=item33840130f6&vxp=mtr
Phil
I see were it could be called a "two piece", because the yoke is separate from the shaft via the U joint. Mine looks like the one in the e-bay listing that fiftee3 provided.
Awesome guys. One less thing...
iused a 78 olds cutlass driveshaft for my 46 1/2 when I put the T-5 and s-10 rear in it....had to have it cut down tho,..cost 38.00
Just an update:
Picked up a '92 Astro rear shaft today. Complete with yoke and joint.
Fit as if it were made for the application. Yoke slips onto the T5, U Joint fits the Blazer axle perfectly.
Cost? $20.
Q
Q Offline
A 2 piece drive shaft consist of 2 drive shafts 3 ujoints 1 on each end and 1 in the middle with a slip yoke and a hanger bearing. Typical found on longer wheel base vehicles. The one piece is just that, one drive shaft including joints and yoke.
