8 members (1955 1 Series, 39Master85, 5 Window 9434, 52Carl, Hotrod Lincoln, UtahYork, Bill Hanlon, 1 invisible),
117
Mod | | | Forums66 Topics128,089 Posts1,056,355 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 388 'Bolter | | 'Bolter Joined: Jul 2013 Posts: 388 | I'm not exactly sure how to go about fixing the edges where the fender bolts to the bedside. Both fenders have damage here. The other one is worse, but it was in another barn. The edge is rusted through, and has broken free along the top edge at the 90* bend into the fender itself. Any suggestions or tips are appreciated!! Picture
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | I would cut it out and weld in new.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Mar 2010 Posts: 10,286 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,286 | That is probably the easiest place on the entire truck to cut out, fab a patch, and weld back in without any risk of warping due to the support provided by the 90 degree fold in that area. When you get it taken care of, don't get cocky kid, you won't be so lucky in other areas. Carl
| | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | I recently have done that weld. It is indeed easy, even for poor welder like me. Give it a shot.
Drew
