4 members (stlcardinalsguy, RLB, 2-Ton, Leo), 127 guests, and 1 robot.
Topics128,136
Posts1,056,427
Members48,441
I'm not exactly sure how to go about fixing the edges where the fender bolts to the bedside. Both fenders have damage here. The other one is worse, but it was in another barn.
The edge is rusted through, and has broken free along the top edge at the 90* bend into the fender itself.
Any suggestions or tips are appreciated!!
I would cut it out and weld in new.
Dennis
40 Chevy 1/2 ton
That is probably the easiest place on the entire truck to cut out, fab a patch, and weld back in without any risk of warping due to the support provided by the 90 degree fold in that area. When you get it taken care of, don't get cocky kid, you won't be so lucky in other areas.
Carl
This thread shows a different fender altogether, but should show how to tackle some of the issues you'll face in making, fitting up, and welding a fender patch panel..
http://www.garagejournal.com/forum/showpost.php?p=935825&postcount=93
I recently have done that weld. It is indeed easy, even for poor welder like me. Give it a shot.
Drew
