3 members (klhansen, 3800GUY, 1 invisible), 63 guests, and 3 robots.
Topics128,153
Posts1,056,847
Members48,456
My idle set screw keeps backing out of the bracket on my 2100.
I was having problems with poor running and stalling after 10-mile runs and SWEET located the problem for me on the side of the road. The root problem is likely a vibration in the engine bay, but I'll have to find that to fix it. Duct-taped the set screw to keep it from leaving me and all was fine on the return trip home.
Was wondering if you guys had a simple fix for the set screw issue.
Here's the carb. Set screw is in the lower right.
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
Thanks Denny,
Wasn't sure if you could use this stuff and still have it adjustable. Appreciate the input.
Jim
235, 3-speed w/OD
Carburetion specialist
Note the screw runs through two "arms" of a U-shaped bracket. There is supposed to be just enough interference to prevent the screw from moving freely.
Remove the screw, and then take a pair of vice-grips and clamp the two arms SLIGTLY together to add a touch of interference. Then reinstall the screw.
Jon.
The Carburetor Shop
Remove the screw and screw a nut on it screw it back on set you're idle speed than use the nut to keep it tight.
Pete
Riding in the Passing Lane
These are all good sugestions. I was thinking of putting a spring on it like a mixture screw.
1972 Chevy c10 Cheyenne Super
The spring will work, but another option is to epoxy a Nylock locknut to the throttle linkage so it holds the idle speed screw at whatever place you adjust it. It's a simple, permanent fix that doesn't look out of place to the casual observer. Install the nut with the nylon locking insert away from the linkage and use something like J-B Weld to attach it to the throttle bellcrank.
Jon.
He is called 'carbking' for a reason. If you bend the U-shaped bracket together by a distance equal to 1/2 the pitch of one thread on the screw (carbkings 'slightly' reference), you should have what you need. I did it on my 52 twenty-nine years ago. It is the subtle things like this that make this hobby so much fun.
Thanks for all the great suggestions, guys.
I must admit I was flabbergasted by carbking's suggestion; It's brilliant! I ran right out and gave it a try. MUCH better now! If the rain holds off today, I'll take a long run and test it out.
Something to be said for the wealth of knowledge and experience here. I had been puzzling this twelve ways from Sunday and kept thinking of things to add to the system when the solution was to tweak what I had.
THANK YOU carbking! And thanks to all who gave the other terrific solutions. I already know a spot where I'll be using the nylock idea.
Best Wishes,
Jim
235, 3-speed w/OD
