5 members (55shaker, 49nut, ndkid275, Gdads51, Rusty Rod), 112 guests, and 3 robots.
Topics128,130
Posts1,056,367
Members48,441
#993257 12/17/2013 9:19 PM
Hello all,
My name is Ron, I live in northern Ca. I just picked up a 1950 GMC 1/2 ton 5 window. I plan on doing a street rod out of it. I will be doing a frame off, and adding corvette suspension. Not sure of the motor yet. I have a 383 stroker sitting in the garage, but was also thinking modern fuel injected motor. I will be using a 700r4 tranny. My first question is Who has the best quality replacement body panels? There are so many companies selling parts for these trucks. I just want to get feed back on who is good, and who to stay away from.
Ron
1950 Gmc 100
Many of the panels sold by the majority of the vendors come from the same source, and that ain't in the USA. If you can be more specific about what panels you need, I can help steer you in the right direction for some of them. I have replaced just about every panel offered on one truck and several on another.
Carl
Thanks Carl.
I need a complete bed, front fenders, and new floor pans. The seat riser is good, just need the panels from the seat riser to the cowl. The cab is in pretty good shape everywhere else. Just has some holes where your feet would be. The front fenders may be fixable. No rust just some creases. I know the bed and fenders are bolt on and can be tweaked to get the best alignment. I just want to have heavy gauge panels, that are going to look as close to original as possible.
1950 Gmc 100
For the bed parts the best quality parts are going to be from Mar-k they stand by their parts and they are made in the USA. See their products at Mar-k.com
I bought my floor panels from Classicparts and they were a nice fit. Check the condition of the pinch weld where the floor meets the toe board. You may want to remove the floor board before you order to check it closely. They sell a floor board with a section of the toe board attached. The only problem with the combination piece is that it won't be factory correct due to elimination of the pinch weld area.
Thanks alot guys. I am hoping to get the body off the frame over the holidays. I have to do the frame work before I start the body. I will keep everyone posted and get some pics posted soon.
Ron
1950 Gmc 100
