| | | Forums66 Topics128,115 Posts1,056,294 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2013 Posts: 45 'Bolter | | 'Bolter Joined: Dec 2013 Posts: 45 | Hello all, My name is Ron, I live in northern Ca. I just picked up a 1950 GMC 1/2 ton 5 window. I plan on doing a street rod out of it. I will be doing a frame off, and adding corvette suspension. Not sure of the motor yet. I have a 383 stroker sitting in the garage, but was also thinking modern fuel injected motor. I will be using a 700r4 tranny. My first question is Who has the best quality replacement body panels? There are so many companies selling parts for these trucks. I just want to get feed back on who is good, and who to stay away from. Thanks, Ron
1950 Gmc 100
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Welcome to the Stovebolt, Ron. There is so much info here you will never run out of something to read or check on.
Since this is the Welcome Centre your question would be best answered in the Paint and Body Forum. Not everyone coming into the forums stop in the welcome centre but go straight to their area of expertise and then branch out to the other forums.
.... but since you ask. Most of the panels will be made by the same company or probably no more than two. Its been said over and over that regardless of where they come from they will most likely require some "fitting". Especially when you realize how these trucks were used, repaired and even assembled at the factories back then. Around here on the East coast I dare say JimCarter and Classic Parts probably gets the bulk of the business but there are others. Then you have the Truck Shop which is in your state of California. I personally have ordered floor pans from them, mainly because of price, and have been satisfied...... I will add that JimCarter does have some panels, or he did just a few short years ago, that are made in the USA. When I visited there I was told the primered looking panels were USA made and the shiny black pieces are all from across the water. Depending on whether its a burb, panel or pickup there is a guy here who hand makes some panels.
Take a little time to learn your way around here on the bolt. Check out the Links section and the tech tips along with learning how to do a search. There is just so much here. ....and, since you are new you are "moderated" for your first 4 post which is to help keep this site free from spammers and other unwanted guest. After 4 post you will then be able to send PM's (private messages) and enjoy all the benefits of being a Stovebolter. Good luck, we're here to help and don't be shy. Visit often, and post a pic of your truck when you can. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 | Hi Ron, welcome. Hard to add anything worthwhile to Alvin's comprehensive reply. Original parts are the best, if they are in good shape, but virtually impossible to find anymore. Have fun with your project.
Leo | | |
