5 members (Shaffer's1950, Gdads51, Otto Skorzeny, Wayne67vert, Hotrod Lincoln), 96 guests, and 1 robot.
Topics128,139
Posts1,056,454
Members48,441
#992492 12/14/2013 2:17 PM
1 Offline
I will be going with 12V system. Can I just restore my heater as is and install or do I need to change the motor to 12V or add something to convert it?
Thanks!
I used the 6 Volt motor untill it burned out. If you have it apart, look around for a 12 Volt. I think I got one at a local parts store that fit , but I had to shorten the shaft a little. Better to fix it now than in the middle of a blizzard. Been ther done that.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
A 12V motor is the only way to go. Unlike a starter were you can use a 6V in a 12V system since it's not operated for long stretches, a blower is on for long periods and will burn out as mentioned above. I see 12V motors on ebay all the time or perhaps a small motor shop near you can rebuild yours at less expense.
Ed
I have converted my truck to 12V. The heater motor is still 6V. I wired in a voltage converter. I had the converter left over from a previous project. The one I installed is similar to the one listed below.
http://www.ebay.com/itm/48-55-F1-6V...h=item3cd9d8f78b&vxp=mtr#ht_63wt_986
H Online: Content
Voltage-dropping resistors develop a LOT of heat and they are a burn and/or fire hazard unless they're installed in the airflow from the fan. Just swap to a 12V blower motor- - - -it should last for a lot of years and they're not that expensive.
No energy goes away. It can only be converted to another form of energy. The voltage drop resistor takes half of the electric energy and converts it to heat (another form of energy)
1 Offline
My 6 volt motor lasted about 15 minutes at 12 volts. Change it now if you have heater out.
I have used a drop resistor with my heater for 20+ years. No problems so far. Then again, who in Calif needs to use a heater? LOL
Craig
Quote
Absolutely, they will work. But the comment on the resistor getting hot is correct thanks to physics.
I concur with those that say change the motor, best cleanest safest way to do so.
$34 at american classic, you may find for less somewhere. Was a perfect fit in mine.
http://www.americanclassic.com/Google_Base_HTML_Pages/EL116-1951.htm
Mike
1951 Chevy 3600 rust bucket with GarWood dump bed conversion
http://www.flickr.com/photos/mikeybs51chevy
1965t5 #994589 12/24/2013 10:08 PM
Today I drove around and finally turned on my heater, reaching for the resistor and dang! That pup got hot. Need to reconsider.
Craig
