2 members (dt235sd, Peggy M),
76
Mod | | | Forums66 Topics128,130 Posts1,056,713 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | the base on my hood ornament is bent and has a broken off piece. the chrome shop that I went to says it cant' be repaired. I'm looking for another one. but while looking on the computer I came across a product called muggy weld. has any one used this? does it work? does anyone know of a shop that could do the repair? thanks, brian | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Brian, Can you post a photo of the parts? It is hard to make recommendations without seeing the damage. I have a few front emblems with different problems. Are you referring the the standard 54/55 front hood emblem or the accessory hood ornament (eagle)? | | | | | Joined: Dec 2011 Posts: 402 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 402 | Brian,
I have used MuggyWeld a fair amount while working on parts for old tablesaws that are no longer made. I also used it as a quick-and-dirty way to fill the pinholes in my brass radiator tank and it hasn't leaked since.
I don't know whether the strength is the same, but I have been unable to break the parts apart that I "welded" with this stuff. In my humble opinion, it's a GREAT low-heat brazing product that works especially well for pot metal. It's just as easy to use as plumbing solder. I plan on using it to repair my own hood ornament when I get around to that.
You have to use their flux solution, but it makes it easy for a novice like me to tell if you're getting the right amount of heat going.
I have been very happy with it.
Best,
Jim | | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | thank for the replies. tim, my ornament is the eagle but it's much longer than any that I have ever seen. its at the chrome shop so I can't get an measurement but I would guess its about 16-18" long. jim , that's why I want to fix it. | | | | | Joined: Mar 2011 Posts: 204 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 204 | I just checked the outline on the hood and its 15". the holes are 12" apart. is that longer or does it look longer than the ones in the catalogs? | | |
