5 members (78buckshot, 49oneton, Napco Man, Otto Skorzeny, tclederman), 121 guests, and 2 robots.
Topics128,115
Posts1,056,623
Members48,450
#991956 12/11/2013 3:54 PM
the base on my hood ornament is bent and has a broken off piece. the chrome shop that I went to says it cant' be repaired. I'm looking for another one. but while looking on the computer I came across a product called muggy weld. has any one used this? does it work? does anyone know of a shop that could do the repair? thanks, brian
1955 First series 3600 3/4-ton
"A Great Starting Point"
Follow the story and pix in the DITY Gallery
Brian,
Can you post a photo of the parts? It is hard to make recommendations without seeing the damage. I have a few front emblems with different problems.
Are you referring the the standard 54/55 front hood emblem or the accessory hood ornament (eagle)?
Brian,
I have used MuggyWeld a fair amount while working on parts for old tablesaws that are no longer made. I also used it as a quick-and-dirty way to fill the pinholes in my brass radiator tank and it hasn't leaked since.
I don't know whether the strength is the same, but I have been unable to break the parts apart that I "welded" with this stuff. In my humble opinion, it's a GREAT low-heat brazing product that works especially well for pot metal. It's just as easy to use as plumbing solder. I plan on using it to repair my own hood ornament when I get around to that.
You have to use their flux solution, but it makes it easy for a novice like me to tell if you're getting the right amount of heat going.
I have been very happy with it.
Best,
Jim
1957 Chevrolet 3100 Stepside
235, 3-speed w/OD
thank for the replies. tim, my ornament is the eagle but it's much longer than any that I have ever seen. its at the chrome shop so I can't get an measurement but I would guess its about 16-18" long. jim , that's why I want to fix it.
I just checked the outline on the hood and its 15". the holes are 12" apart. is that longer or does it look longer than the ones in the catalogs?
