4 members (Joe H, 68ironhead, baldeagle, 78buckshot), 72 guests, and 5 robots.
Topics128,014
Posts1,055,329
Members48,419
#99167 02/07/2007 5:12 PM
Quick question: I have a 1954 3100 6 volt truck. Does it matter or is there a difference between a 6 volt light switch and a 12 volt light switch. I think it doesn't matter!!!! but Am checking here.... Peter
#99168 02/07/2007 5:42 PM
Peter,
The stock switch would work fine on 12 volts. The only caveat would be if it has on-board circuit protection of any kind. A fuse or thermal would be rated for current flow at 6 volts..this might not offer proper protection for lights etc at 12 volts.
If it does have a fuse or some replaceable type of protection, it would have to be scaled down to cover 12 volts.
Stuart
#99169 02/07/2007 9:33 PM
Peter,
The 1954 6v light switch works fine at 12v for all the components that were normally connected to the light switch (mine has worked at 12v for over 8 years). I assume this is also correct for pre-1954 light switches - they are slightly different but are often used interchangeably by changing the knob/stem - the knob stems are different lengths and there might be other internal differences.
Tim
