Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
3 members (carbking, baldeagle, NJC), 35 guests, and 2 robots.
Topics128,005
Posts1,055,254
Members48,418
#989335 11/28/2013 3:14 PM
I am going to look at a 46 GMC dump truck and was wondering what size of motor they came with?
Buckstruck #989360 11/28/2013 4:45 PM
3B Offline
Hy Buckstruck, It could come with many different engines depending on just what size of truck it is. GMC built trucks far in excess of the capacity of their Chevrolet cousins. If the truck is comparable in size to a Chevrolet, then it would probably have a 248 or 270 GMC engine, hope that helps.
Buckstruck #989383 11/28/2013 6:04 PM
Remember to look at the flat pad at the base of the distributor, the first 3 didgits on that pad are the engine size.
JeffL #989511 11/29/2013 12:36 PM
Thanks guys.
Buckstruck #989653 11/30/2013 5:46 AM
According to the factory book for '46, standard issue for engines was as follows for each series...
3000 thru 4000 : 216.5 THRIFT-MASTER (90HP @ 3100 RPM - Torque= 174@1200-2000 rpm)
5000: 235.5 LOAD-MASTER (90 hp @ 3100 rpm - Torque= 189 @ 1000-1900 rpm)
6000: 235.5 LOAD-MASTER (93 hp @ 3100 rpm - Torque= 192 @ 1000-1900 rpm)
Obviously the bigger trucks had bigger engines but the 6000's must have been "tweaked" just a tiny bit. Note that all the above are "gross" ratings.
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
Buckstruck #989666 11/30/2013 8:28 AM
Tango, He has a GMC.
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Buckstruck #989693 11/30/2013 4:59 PM
Thanks Spanky --- that's what I get for tryin to read writin when it's wrote.
The numbers posted are indeed for Chevy's. No ideer what the Jimmy's might be.
Buckstruck #990286 12/03/2013 3:47 PM
228?
Buckstruck #990316 12/03/2013 7:13 PM
A 46 300 series would have probably had a 236 in it. A little larger truck would have a 248 in it. But you never know what someone may have installed in it during the past 70 years. A 228, 236 and 248 are totally interchangeable.
Buckstruck #990757 12/05/2013 6:40 PM
Crusing in the Passing Lane
It could also be a 'big block' 6; 427, 503?
Buckstruck #990759 12/05/2013 6:48 PM
unfortunately the 55-59 GMC manual isn't going to help with specifics but it might give some clues as to how GMC did things... 55-59 GMC data page from OCMP
Give me ambiguity
or give me something else
Buckstruck #992391 12/13/2013 10:20 PM
If it is a 300 series it probably will be a 228 CID. Else it is a GMC 216 (not Chevy 216).
I just bought a 1949 GMC 350(2 ton)flat bed with dump hoist. It is all original from Southern Pacific Railroad. It has a 228 CID in it. I checked the numbers on the block...
If the truck was built in Canada it could have a Chevy 216 in it.
Need to see picture of engine.
As suggested above check numbers on block that will end any confusion.
GMCPic
Dance like no one is watching,
Sing like no one is listening,
Love like you've never been hurt.
1948 GMC FC101 1/2t Pickup w/270 and SM420
1948 GMC FC253 1t Factory 80"x9' Flatbed Dually
1948 Chevy COE 2 Ton 8'x15' Flatbed
1950 GMC 354-24 2 Ton 8'X12' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton 8'x14' Flatbed w/Dump Hoist
1953 GMC 454-30 3 Ton Cab and Chassis
1942 Clarkator 6 MILL-44 Heavy Aircraft Tug
1942 Ford (9N) Moto Tug with 1/2 yard Loader
1947 Oliver OC3 HG-42 Tract-Crawler Bull Dozier w/6' Blade
