1 members (78buckshot),
43
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2013 Posts: 73 | Well I had some paint maybe 20 years ago that was advertised to both kill rust and create a hard primer surface to be painted over. I can't locate anything like it now and maybe it wasn't as good as advertised. but it seemed to work on an old Jeep I worked over years ago. does anybody know of such a product on the market now? I realize the need to get any loose rust and scale off first but it seems if there is anything like that good out there it would help me. Raymond | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | My guess would be epoxy primer! | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | I doubt epoxy primer compares to 20 year old paint...unless it was Imron.
| | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Might look at Zero-Rust Skelflyer.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Maybe what I should of said was 20 year old paint doesn't compare with epoxy primer... unless it's Imron??? But seriously... if something 'claims' to stop, reverse or 'cure' rust issues by just painting over it, I go looking for my hip waders...
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Now that's the way I feel about POR treatments. I'm a believer in first "getting rid of the rust", then painting the bare metal as the only real way to treat a rusty component, not painting over rust.
Denny G
Spose I should make mention that when I posted POR I meant Painting Over Rust as a generic term, not the product POR-15.
Denny G Sandwich, IL
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Well, soon POR-15 will be POR-20. I remember when it was POR-10 (was it ever POR-5?). I have seen a test part that has been exposed for over 10 years (laying on the ground, outside a shed in Stephentown, NY). No rust. It has discolored some, due to UV exposure. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | There are shortcuts and there isn't anything wrong with them, like POR products. These products get the job done. There are so many different levels of 'getting the job done' that its hard to place where POR or Eastwood equivs would place.
If you want a truly superior job, and the technology has changed dramatically in the past 10 years, you will want to go with the newer Epoxy primers after sandblasting and metal prepping the surface. Once epoxy primer is applied, urethane high build to solve any imperfections, epoxy sealer, then topcoats (either single stage urethane, or Basecoat/Clearcoat), also Urethane based.
POR 15 and the like are great if you don't sandblast, but rather just wire brush the rust and crud off the surface. Some people don't have the ability or inclination to sandblast, thus why the POR products are popular. These are the guys that boast that their trucks are a '20 footer'.
The problem with not sandblasting to the bare metal is that chemicals like brake fluid (Or grease etc) that permeate the metal and will stay on the metal even after the POR or whatever is applied. Now you have an accident waiting for a place to happen. Just not worth it. Even if you are a POR fan, clean with at least PPG DX-330 very well before applying. If its not blasted, that wont even work since the rust layer absorbs too much of the bad chemicals and will always be present until you blast it off. Chemical stripping is an invitation for that chemical to seep into seams where you cant clean it out, thus leaving a dormant chemical just waiting to ruin your paint job a few years later from the inside.
Whenever I hear someone chem stripped their truck, and the paint job looks really good, I just look at the cab rain gutter and there it is.. bubbled paint that will be noticed by the owner a few months later.
No question, POR products have their place. And they work WELL if the metal is prepped properly first. Sandblast, apply epoxy primer, then POR 15 and all is as you could expect. It isn't the way any painting professionals would suggest, but its cheaper and a way for novices to get things done. If you listen carefully to the auto paint professionals, none of them have POR products or anything like them in their arsenal. | | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | Rust in seams, seems to be the worst to get rid of or prevent....
Many types of rust preventive paints are out there. POR-15, Miracle Paint(Bill Hersch), Zero Rust.....
John | | |
