8 members (Donald Colaluca, 55shaker, TexasA&M48Truck, baldeagle, JW51, Bill Hanlon, Jay R, 1 invisible),
32
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,252 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 30 New Guy | | New Guy Joined: Sep 2013 Posts: 30 | Hello, I have a Watson Transmission, Spicer Brown-Lipe Model M45 serial #013737. It has a stamped #C30-15118-7 on the left side of the case. It also has a casting # C30-22-25 on the front of the case. The information I've gather so far, is that it's a 3 speed. it has an under drive, a drive and an overdrive. I've searched the Internet for information but haven't had much luck. Does anyone have a manual of any kind that would show me how to use this type of transmission? Or does anyone have personal experience driving with this particular model? I would greatly appreciate any help. I've posted a couple of photos of the "Brownie" on my Flickr. Thank you, Lisa
| | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | What is it you want to know about it?
1947 M15 Studebaker 454 4x4 1949 Chevy COE In the Stovebolt GalleryMore pix of the COE1950 Harley FL 1958 GMC LCF 455 3x2bbl 1961 Chevy C60 Tilt Cab 327 1966 Chevy C60 Tilt Cab 496 1961 Chevy K10 sb 292 1974 Harley FXE 1979 Chevy K10 sb 2007 Harley Streetglide I'm not that good but I'm slow
| | | | | Joined: Sep 2013 Posts: 30 New Guy | | New Guy Joined: Sep 2013 Posts: 30 | Hi Goob,
I'd like to know how to shift through all the gears properly.
Lisa | | | | | Joined: Apr 2013 Posts: 172 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 172 | properly is a "loaded" question...no pun intended. There will be a lot of different opinions on how to use it. Depends on a lot of factors. An auxiliary trans is really for a "loaded" tuck. It gives you a lower set of gears for starting, hills, and moving around slowly. For you it is probably just bragging rights and a cool accoutrement for the truck. I would just leave it in direct for most driving and you might use the OD in forth if your on flat ground or going down hill, and IF you want to go that fast.
Thank you for the info.
Lisa | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Hey,coegirl! NICE COLLECTION!! There was quite a discussion,here on this forum,on this very subject! The Watson,was built by Brown-Lipe,in California. If you plan on keeping the tranny,it would be a COOL addition,for either your C.O.E.,or L.C.F.On "youtube",there's a video,(by:"Paulybuilt",featuring a '65 G.M.C.4000.Near the end of the video,the "Jimmy" gets passed,by an A.D.Chevy 6500,pulling a trailer!! The Chevy is equipped with a"Brownie" 3-speed.If you P.M. "Pauly",I'm sure he'd be happy to tell you how the unit is installed,and the parts needed to complete the transplant.If you decide to sell it,Please post it in the "Parts For Sale",and I'll bet you it sells in less than 2-days! there's a BUNCH of "Big-Bolters",that at least have a "Brownie" on their "Wish list"! If I found a "Brownie" (O.D.),myself,I'd HAVE to install it! It lets you go faster(,on level ground),while reducing engine R.P.M.'s at the same time!! PLUS,PLUS!! | | | | | Joined: Sep 2013 Posts: 30 New Guy | | New Guy Joined: Sep 2013 Posts: 30 | Hi Wetwilly57575, The Brownie is installed in my COE and I plan to keep it in there but, I wanted to learn how to drive/use it properly. I'd love to hear from those Big Bolters that have personal experiences with this type of Brownie. Thank you, Lisa  | | | | | Joined: Nov 2011 Posts: 104 Shop Shark | | Shop Shark Joined: Nov 2011 Posts: 104 | Using the overdrive trans isn't necessary unless you plan to pull a trailer and some weight. As mentioned you can use the low range to get a heavy load moving by splitting the main and aux box and stepping up thru each gear. Without weight, there is no point to use the low range. You could use the overdrive as a splitter to reduce the rpm drop between gear changes on the upper end and for more top speed. Driving a 2 stick takes some practice and there are no syncros in the aux box, so you need to match speed and rpm when shifting it. Double clutching will help but isn't like moving the stick from one gear to the next in the main box.
1952 Chevrolet 6400 flat bed
| | | | | Joined: Sep 2013 Posts: 30 New Guy | | New Guy Joined: Sep 2013 Posts: 30 | Thank you for all the great suggestions. It's greatly appreciated. | | | | | Joined: Feb 2004 Posts: 29,740 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,740 | Did you get the PM I sent you about shifting the main and auxiliary transmissions? I learned to use a 5X3 setup in a B-73 Mack about 35 years ago. Mack called it a "Tri-Plex" and it was actually two transmissions in a single housing, using two separate shifters. They also had a 4X4 known as a "Quadri-Plex". With a little practice, you can learn to make just about all the shifts without using the clutch, just matching RPM between gears and making shifts with no gear grinding or damage. Jerry
| | | | | Joined: Sep 2013 Posts: 30 New Guy | | New Guy Joined: Sep 2013 Posts: 30 | Hi Jerry! Yes, Thank You. Lisa  | | | | | Joined: Jan 2007 Posts: 446 Shop Shark | | Shop Shark Joined: Jan 2007 Posts: 446 | Try YouTube as well. If I remember right there are some good videos showing how to shift. Nice trucks you have. Great pictures on Flickr  | | | | | Joined: Sep 2013 Posts: 30 New Guy | | New Guy Joined: Sep 2013 Posts: 30 | | | |
