Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (thekid1950, baldeagle, Steelonsteel, cmayna, Rusty Rod, 78buckshot), 50 guests, and 2 robots.
Topics128,006
Posts1,055,268
Members48,418
Hello,
I have a Watson Transmission, Spicer Brown-Lipe Model M45 serial #013737. It has a stamped #C30-15118-7 on the left side of the case. It also has a casting # C30-22-25 on the front of the case.
The information I've gather so far, is that it's a 3 speed. it has an under drive, a drive and an overdrive.
I've searched the Internet for information but haven't had much luck. Does anyone have a manual of any kind that would show me how to use this type of transmission? Or does anyone have personal experience driving with this particular model?
I would greatly appreciate any help. I've posted a couple of photos of the "Brownie" on my Flickr.
Thank you,
Lisa smile
coegirl #988927 11/26/2013 6:35 PM
What is it you want to know about it?
1947 M15 Studebaker 454 4x4
1949 Chevy COE
More pix of the COE
1950 Harley FL
1958 GMC LCF 455 3x2bbl
1961 Chevy C60 Tilt Cab 327
1966 Chevy C60 Tilt Cab 496
1961 Chevy K10 sb 292
1974 Harley FXE
1979 Chevy K10 sb
2007 Harley Streetglide
I'm not that good but I'm slow
coegirl #988936 11/26/2013 7:02 PM
Hi Goob,
I'd like to know how to shift through all the gears properly.
Lisa
coegirl #988960 11/26/2013 9:32 PM
properly is a "loaded" question...no pun intended. There will be a lot of different opinions on how to use it. Depends on a lot of factors. An auxiliary trans is really for a "loaded" tuck. It gives you a lower set of gears for starting, hills, and moving around slowly. For you it is probably just bragging rights and a cool accoutrement for the truck. I would just leave it in direct for most driving and you might use the OD in forth if your on flat ground or going down hill, and IF you want to go that fast.
1949 Chevy COE
More pix of the COE
1950 Harley FL
1974 Harley FXE
1979 Chevy K10 sb
coegirl #989002 11/27/2013 2:09 AM
Hi Goob,
Thank you for the info.
Lisa
coegirl #989066 11/27/2013 6:39 AM
Hey,coegirl! NICE COLLECTION!! There was quite a discussion,here on this forum,on this very subject! The Watson,was built by Brown-Lipe,in California. If you plan on keeping the tranny,it would be a COOL addition,for either your C.O.E.,or L.C.F.On "youtube",there's a video,(by:"Paulybuilt",featuring a '65 G.M.C.4000.Near the end of the video,the "Jimmy" gets passed,by an A.D.Chevy 6500,pulling a trailer!! The Chevy is equipped with a"Brownie" 3-speed.If you P.M. "Pauly",I'm sure he'd be happy to tell you how the unit is installed,and the parts needed to complete the transplant.If you decide to sell it,Please post it in the "Parts For Sale",and I'll bet you it sells in less than 2-days! there's a BUNCH of "Big-Bolters",that at least have a "Brownie" on their "Wish list"! If I found a "Brownie" (O.D.),myself,I'd HAVE to install it! It lets you go faster(,on level ground),while reducing engine R.P.M.'s at the same time!! PLUS,PLUS!!
Mo' Tater
wetwilly5757 #989184 11/27/2013 8:57 PM
Hi Wetwilly57575,
The Brownie is installed in my COE and I plan to keep it in there but, I wanted to learn how to drive/use it properly. I'd love to hear from those Big Bolters that have personal experiences with this type of Brownie.
Thank you,
Lisa smile
coegirl #990791 12/05/2013 9:51 PM
Using the overdrive trans isn't necessary unless you plan to pull a trailer and some weight. As mentioned you can use the low range to get a heavy load moving by splitting the main and aux box and stepping up thru each gear. Without weight, there is no point to use the low range. You could use the overdrive as a splitter to reduce the rpm drop between gear changes on the upper end and for more top speed. Driving a 2 stick takes some practice and there are no syncros in the aux box, so you need to match speed and rpm when shifting it. Double clutching will help but isn't like moving the stick from one gear to the next in the main box.
1952 Chevrolet 6400 flat bed
Bigdreamer #991044 12/06/2013 11:57 PM
Thank you for all the great suggestions. It's greatly appreciated.
coegirl #991059 12/07/2013 1:12 AM
Did you get the PM I sent you about shifting the main and auxiliary transmissions? I learned to use a 5X3 setup in a B-73 Mack about 35 years ago. Mack called it a "Tri-Plex" and it was actually two transmissions in a single housing, using two separate shifters. They also had a 4X4 known as a "Quadri-Plex". With a little practice, you can learn to make just about all the shifts without using the clutch, just matching RPM between gears and making shifts with no gear grinding or damage.
Hotrod Lincoln #991402 12/08/2013 7:44 PM
Hi Jerry!
Yes, Thank You.
Lisa smile
coegirl #991480 12/09/2013 2:15 AM
I
I Offline
Try YouTube as well. If I remember right there are some good videos showing how to shift. Nice trucks you have. Great pictures on Flickr smile
Iron Clad #991704 12/10/2013 4:55 AM
Thank you, I will.
