1 members (Gray_Ghost),
72
0
Mod | | | Forums66 Topics128,050 Posts1,055,761 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Deleted
Denny G Sandwich, IL
| | | | | Joined: Sep 2013 Posts: 93 Shop Shark | | Shop Shark Joined: Sep 2013 Posts: 93 | Why not just drill? My Bosch concrete drill never had a problem if it hit Re-bar. Just had to move the hole location. Mesh is not a problem, will Go right through it. Glad to lend you my Bosch if necessary.
1947 GMC Truck 5 window, Long Bed 2008 Corvette Roadster 2008 Harley Davidson FXDL 2011 F150 Ecoboost 4X4 2015 Subaru Outback AWD "only the strong survive"
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | If it does penetrate the concrete would it provide you any useful data? If you have wire it'll read positive everywhere and could possibly do that even with rebar if they are close enough together.
| | | | | Joined: Mar 2005 Posts: 684 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 684 | Denny, I used one to find the cables in my garage floor when I installed a 2 post lift. My concrete is pre stressed with cables. I did not want to hit one of those with the drill bit. The metal detector worked fine. Cleon | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | Google "Zircon metalliscanner MT 6"...
I would paste links but Kindle - limited...
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Call the underground utility locater people. if you have cables of other lines under the floor, they can find them with their fancy doohickey. They might be able to locate the rebar if you can talk them into it. Best of all.....it's free.
Bruce | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | 10-4 on the 811 in the yard.
If you don't call the utilities you get to pay if you dig up their stuff. If you call 811 then you have a chance they will fix it.
R-Bo
| | | | | Joined: Jan 2008 Posts: 4,961 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,961 | I use dowsing rods to find water as well as metal. Contrary to a lot of belief, it has nothing to do with witchcraft. And I have not promised my soul to the devil either. I think it has something to do with magnetism. When I graduated from high school and again when I graduated from college, my parents bought me very expensive wind up watches. Neither one of them would run a week. Every jeweler in town told me I had too much magnetism in my body. I have no trouble with quartz watches. | | |
