2 members (78buckshot, 1 invisible),
390
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2012 Posts: 26 New Guy | | New Guy Joined: Jul 2012 Posts: 26 | Bolters, I did a quick search and didn't come up with this info...so I will jump right in. I recently subscribed to a little paper/magazine called Farm Show. ( www.farmshow.com...which I HIGHLY recommend!)It is a collection of all the incredibly creative things that people do on their own to invent, create, re-purpose and generally do amazing things with old iron! In their "More Great Shop Ideas" magazine you get free for subscribing there is an article on Homemade Penetrating Oil. Seems that Machinist's Workshop magazine did a test of all the major branded penetrating oils back in '07 by artificially "rusting" what appears to be pins inserted into place and then measured the force it took to press them out. They found that the best/easiest product was a 50/50 homebrew mix of ATF and Acetone! There test ran from Nothing-requiring 516 pounds to the best performing OTC Kano Kroil spray at 106 lbs and all the way down to...yep, you guessed it the Homebrew at just 53 lbs. I gotta go down to Ace and get some Ace-tone  | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | How much experience have you had using acetone? Let an old geezer who has managed to survive his own stupidity offer some friendly advice about the stuff. Wear some good-quality rubber gloves while using it, and either use a good respirator or at least have a fan blowing the fumes away from you while you're mixing it with the ATF. Acetone is a pretty potent carcinogen, and it absorbs through the skin almost as well as it gets into your bloodstream from inhaling its vapors. Either way, it's pretty toxic stuff. Be careful. Jerry
| | | | | Joined: Aug 2013 Posts: 568 Shop Shark | | Shop Shark Joined: Aug 2013 Posts: 568 | Man I've been rinsing my hands with acetone to get gemseal concrete sealer off. Maybe that's why I'm messed up. Ohh and don't smoke a cigar while pouring it either..
| | | | | Joined: Jul 2012 Posts: 26 New Guy | | New Guy Joined: Jul 2012 Posts: 26 | Guyz, Good advice (well...I'm not so sure about the "hand rinsing" stuff) I've done some pretty risky things in my lifetime with chemicals as well. Now, after they've outlawed stuff like Trichloroethylene, etc. I'm much more careful. My thought process now runs toward treating anything more caustic than kerosene like it's acid and then go from there. | | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Acetone is extremely volatile and will evaporate within moments of exposure to the air. I read this years ago when it first started circulating. I find it difficult to believe acetone mixed with anything would make a good penetrant since it will evaporate from the compound after application.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | I use a fair amount of acetone as a solvent, particularly with resin work, while it is volatile, I haven't found it to "evaporate within moments" .... and as far as it being "pretty toxic stuff", it's excellent for removing stubborn paints, glue residue, and resins from skin, and while I wouldn't drink it, it is found in some foods - and it's naturally produced in the human bodyas with any chemical, reasonable precautions against ingesting it and it's fumes in quantity is advised Bill | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Jerry, Tiny, Bill, all good comments guys. I've had some experience with Acetone going back to the early 80's. I use to even keep it around to put in my dried up wood filler putty to make it pliable. I've worked around some nasty stuff in my professional life from MEK to Chromic acid. Regardless of what is bad, and what is not so bad, SAFETY conscious folks will always need to exercise good COMMON SENSE. Heck Bill, I've ran a many yds of coating on fabric that contained formaldehyde. We all know what that stuff will do to you...in certain quanities. The same stuff they embalm folks with is, or use to be, found in the meat we eat.
Bottom line, practice good safety ALL THE TIME. I do like the ATF and Acetone mix but the times Kroil wouldn't handle the job has been few. Therefore I don't keep acetone sitting around on the shelf. Just my own personal doings.
Nifty63, as you can see its been around a while. Surprised it didn't show up in your search....but that's why good guys like the ones above are here. To help us. | | | | | Joined: Feb 2004 Posts: 29,871 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,871 | Good points, all! I've worked around some extremely hazardous stuff since the early 1950's when the family race car ran on a mixture of methanol and concentrated hydrogen peroxide that would literally eat the bottom out of a carburetor float bowl if we didn't run the carb dry at every engine shutdown, and chemicals such as concentrated sulfuric acid, acetone, and hydrogen peroxide can be used to produce a high explosive so unstable it must be mixed at the site of its use to avoid unintentional detonation. MEK will dry out skin to the point knuckles crack and bleed. All these things have legitimate uses, just be very careful to protect yourself and others and have a good understanding of the hazards involved.
BTW, KROIL is manufactured about 50 miles north of my place, in Nashville, so picking up a gallon of it is a good reason to take a nice ride on my Gold Wing! Jerry
| | | | | Joined: Mar 2010 Posts: 10,305 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,305 | Does anyone know what is in kroil? I wouldn't be surprised if it had some acetone in it.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Jan 2003 Posts: 354 'Bolter | | 'Bolter Joined: Jan 2003 Posts: 354 | Which carcinogen list is acetone on?
Harold Wilson 41 Chevy 3/4 Ton
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I can't see what acetone does to rust... it doesn't affect it chemically, maybe it breaks down the ATF which would have friction modifiers and some detergent but also nothing that affects rust.
I'd rather just heat a part then try and shoot goo all over it.
Did the test try heat??? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | As noted in the beginning of this thread, that acetone/ATF formula has been around for several years. I've been using it since I first heard about it and it does indeed work just as good if not better than PB Blaster, Kroil or Liquid Wrench. The Acetone simply thins out the oil so it can seep into very small cracks. Here's a link to a copy of that test data: http://www.garagejournal.com/forum/showthread.php?t=59511 My experience with Acetone goes back many many decades. I've been using it for cleaning, thinning or removing since I was a kid. It was one of the only chemicals that we used at the accelerator lab that I worked at for 30 years that wasn't banned as a cleaning agent. The lab was operated under contract to the DOE who was so strict that we couldn't have any lead in the shop and Simple Green was banned. Acetone is used as a paint thinner and it's the main ingredament in your ladies finger nail polish remover. As with any chemical solvent, just don't drink it or take a bath in it. There seems to be a misconception that these penetrating oil compounds dissolve rust. None that I know off do that they simply seep into and lubricate the fastener lowering the friction. I found this at several sites concerning the toxicology: "Acetone is believed to exhibit only slight toxicity in normal use, and there is no strong evidence of chronic health effects if basic precautions are followed." Denny Graham Keeping things slippery in Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Apr 2005 Posts: 177 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 177 | i have been using it for the past 5 years best thing i have found and a lot cheaper to make per oz than what you can buy. i put it in a small oil squirt can when i need it then put the rest back in the container till i need it again | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Only draw back is the acetone evaporates pretty quick. I've left my bottle open (old Plockmans mustard bottle) and the acetone don't stick around long if you leave the cap open.
Denny G
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | A link to the original would really clear things up.
What postion was the bolt in (vertical? Horizontal? Upside down?)
What about heat?
I'll put my MAPP torch up against any goo for breaking lose a bolt. Plus when the bolt is vertical or upside down you are hoping for capillary action. Heat physically breaks the rust bonds in any position.
I'll try it, but I'm not getting rid of my MAPP gas anytime soon. | | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | I found THIS LINK where a guy tried it and could not get the solution to mix... it was like oil and water... he called BS on the whole idea. It seems the article dates to 2007... and without the original article a lot of people asked the same question I did.. how did they set up EXACTLY the same rust for 4-6 equal tests? Did they repeat it or just do it once? | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | There's always one, isn't there!
DG
| | | | | Joined: Aug 2005 Posts: 6,378 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,378 | Only draw back is the acetone evaporates pretty quick. I've left my bottle open (old Plockmans mustard bottle) and the acetone don't stick around long if you leave the cap open.
Denny G My point exactly. How can it make a good penetrant when it evaporates so quickly.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Acetone isn't like ether Tiny, it doesn't evaporate so fast that it won't seep into small cracks. Once the solvent does it's job of getting the oil into the threads it isn't needed any more.
If you haven't tried it guys you shouldn't knock it. And one bad apple or experience taken from a Porsche Parts and accessories blog doesn't stack up against the hundreds of other reports that have been posted since this was first published. The way the guy approached the removal of his rusted parts was far from scientific also, that is I'll try this, then that then something else, then finally get a hammer out and blame all the previous attempts as no good. What do you care anyway Richard, Sweetie taint got a rusty part on her anymore, does she???? We pulled the badly rusted complete bed off a friends '50 a few years back and used the Acetone/ATF and to my surprise dang near every old badly rusted nut came off it's bolt/screw. I was just expecting them all to shear off with the impact driver we were using. Bottom line is, like a Ford, Chevy or Dodge, just pick your favorite, they're all pretty much the same.
Denny Graham Sandwich, IL
| | | | | Joined: Sep 2008 Posts: 872 Shop Shark | | Shop Shark Joined: Sep 2008 Posts: 872 | Here's the authors post:
"Allow me to appologize one more time. The test material was intended to be automatic transmission fluid. In the auto parts department, I grabbed a bottle of power steering fluid by mistake. If you read the article, the power steering fluid shown was used. The table you quoted has not been corrected.
One salient point not covered in your question -- these are loads required to free the test piece after 8 hours of immersion in penetrating oil. This is probably not representative of a quick squirt just before a wrench is applied. "
So he used POWER STEERING FLUID, not ATF, so all those cited tables are wrong and people have been living off the placebo effect hahaha
This is one reason why you should NEVER BLINDLY TRUST EVERYTHING YOU READ. Plus the bolts artificially rusted for only a few days using an electrical method (which seems not to be described... so again, cannot say its real world or simply something for a repeatable test).
I say the biggest fault is that heat was not used as a test point. Who waits 8 hours to soak a bolt???? 20 seconds of MAPP and off it comes. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | power steering fluid and ATF are pretty much the same animal, different color, check the data sheets .... and they weren't 'bolts', it was pins in drilled holes all done the same way ... as Denny says, pick your favorite technique, no need to carry on and on
Bill | | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | There are no doubt other methods of getting rusty things loose. No question that heat is faster, many times using heat is not an option. Many times soaking for even days or weeks ends up in a better result than the faster more destructive methods. Anything can be taken apart by some means but when it comes time to put things back together is where it makes a difference. So each to their own but it sure helps knowing more than one way to achieve the same thing. | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | ..... I'm just thankful none of you think WD-40 is a penetrating oil  I have most of what you guys mention. PBblaster, Aero-Kroil, Sili-Kroil, liquid wrench and some AFT but out of acetone. Tried a few others but MY favorite is Aero-Kroil so that's what I use. ....so you guys do the same. Use what works for you. Break time is over, lets get back to work! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Been back to work Alvin, thought I stirred the pot enough the last few days. You're quite right, use what ever is within reach at the time. DG
| | | | | Joined: Sep 2001 Posts: 581 Shop Shark | | Shop Shark Joined: Sep 2001 Posts: 581 | In case it helps:
We use the 50/50 mix ATF & Acetone in our shop. The master mechanic is a retired bus mechanic, and he showed up with a squirt can you can pressurize with air - can't remember what it's called. Anyway, just pull the trigger and it sprays - works great, and doesn't evaporate. Think the air squirt cans are quite pricey, but very nice to have. And yes, practice good sense - wear eye protection, the penetrant splashes back typically.
-Michael
