| | | Forums66 Topics128,115 Posts1,056,294 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | If anyone has this dual horn set up i'd love to see a photo or diagram. Just picked up a set on ebay, think they are the correct ones but cannot seam to find much info. Thanks
| | | | | Joined: Jun 2007 Posts: 134 Shop Shark | | Shop Shark Joined: Jun 2007 Posts: 134 | Here's 2 pictures of how they're installed on my 52 Horns #1 Horns #2 | | | | | Joined: Jan 2000 Posts: 2,074 'Bolter | | 'Bolter Joined: Jan 2000 Posts: 2,074 | Well now after seeing your sets I may have gotten snookered on this pair. Mine look like a pair of squashed trumpets, lots of twisty pipe. Oh well they look neat anyway will give them a try. And I do have the factory horn, been on this truck since new I believe, mounts on intake. Many thanks guys. Jim | | | | | Joined: Sep 2006 Posts: 3,596 'Bolter | | 'Bolter Joined: Sep 2006 Posts: 3,596 | I am hopeful someone else with a 53 may chime in as to factory fit, but I have seen at least a couple of 53 trucks that have a fender mounted small non-trumpet horn. This makes sense with the accessory horn being one mounted to the firewall? Here is a picture of a 53' I owned with this horn. http://www.flickr.com/photos/advance-design_parts_co/8130447759/in/set-72157631870734114 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | In 1953, the second sea-shell style horn (hi-note) truck horn was mounted on the front of the dash (firewall) on the passenger side (an inside reinforcement plate was provided with the accessory hi-note horn). A diagram and instructions are given in the 1953 Accessories Installation Manual.
In 1954/55st, the dual horns were mounted on the front side of the radiator housing/frame.
