4 members (68ironhead, Wayne67vert, GRNHydra, Oswald), 131 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#987177 11/19/2013 4:30 AM
Not long ago, I read a post where someone used a water heater blanket for floor insulation on their truck. Very cost effective and a great idea. Farmers and others who used these trucks did'nt always have the time or money to keep them going and used good o'l Yankee ingenuity. I would bet that there are lots more of these creative ideas out there. Someone care to go first?
53Movinon #987180 11/19/2013 4:47 AM
I had a chunk of truck tire tread as a transmission mount insulator and a spray paint cap as a grease cap on one of my front hubs.
I have a category on my truck blog dedicated to all the "farm fixes" I come across on my truck.
http://rustyfiftyone.com/category/shade-tree/
53Movinon #987239 11/19/2013 3:09 PM
well, i always liked using a rag for a gas cap and of course there is always baling wire for a variety of uses.
1952 Chevy Pickup Truck
53Movinon #987251 11/19/2013 4:01 PM
In a rainy environment, for a truck parked outdoors, a rag for a gas cap might allow water dilution/contamination in the gas tank.
in that situation i use a nylon rag as it tends to shed moisture and not absorb moisture; just a feeble attempt to add a bit of humor.
53Movinon #987267 11/19/2013 5:02 PM
I keep baling wire and duct tape in my "travel kit".
In that kit are also "rubber" gloves (latex and/or nitrile, in case my truck has allergies) - they would serve well as a temporary gas cap.
53Movinon #987286 11/19/2013 5:54 PM
To the original mention of the water heater blanket, I don't use the blanket-type water heater insulation, but the bubble-wrap style water heater insulation, with foil on the outside. When siliconed to all hidden surfaces of the cab it insulates very very well.
My 46 GMC on Photobucket
53Movinon #987353 11/19/2013 9:17 PM
Ex Hall Monitor
Ex Hall Monitor
Creative ideas??? Well, I keep this little number on the wall in my office. A little invention of mine. grin
Tim , I think he is kidding...I hope
46gmcpu #987409 11/20/2013 1:43 AM
46gmcpu, that is the one I'm referring to. Any more ideas?
53Movinon #987449 11/20/2013 4:05 AM
I think he is kidding, too. But, I have had a gas cap stolen at a show and the latex glove came in handy (duct tape was plan B).
53Movinon #987474 11/20/2013 6:12 AM
Actually, in the old days you would occasionally see a rag stuffed in the gas filler neck. Not saying it was a good idea, but it was done.
Rich
1947 Loadmaster
1947 Chev. Loadmaster
1959 Chev. Viking 40
53Movinon #987481 11/20/2013 6:46 AM
Sir Searchalot
Sir Searchalot
Vice grips, ahhh vice grips. Inside door handles, repair throttle, hold a radiator bracket together, and everything else.
53Movinon #987507 11/20/2013 1:51 PM
back yard wrench turner
W Online: Content
for patch panels
License plates
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
53Movinon #987519 11/20/2013 3:18 PM
i was.
53Movinon #987552 11/20/2013 8:32 PM
I once used a park bench for the seat in my old 49 Ford truck. Same truck had a corvair instrument cluster bailing wired in above the steering column. Corvair fuel tank was bolted in the bed.
This is starting to get interesting.
Maybe it's becoming a Greasey Spoon topic?
53Movinon #987676 11/21/2013 4:38 AM
It's moving that way.
53Movinon #987687 11/21/2013 5:38 AM
ok, so the rag in the fuel tank inlet didn't go so well, heck no one had enough gas in the tank to wet the rag anyway; however, here's a few more;
old piece of carpet on the seat to cover the exposed springs.
old metal garbage can lids to cover rusted out floor boards.
wooden wedge in door glass opening to keep the window up;
or if no glass, piece of cardboard mounted in window opening with a small square cutout in order to see out.
did i mention a rag, a red one to cover the tail light when the cover it broken.
did i mention a rag, one wrapped around the wiper blade when the rubber is gone.
did i mention i'm 66 years old, from the south were creative ideas ruled.
oh, i once saw a tin can taped to the outside mirror and used as a cup holder.
did i mention, i'm from the south.
have fun.
53Movinon #987752 11/21/2013 3:20 PM
One time I was struggling to get the truck started, long story. When it finally lit off, the fuel air mix that had been pumped through and subsequently filled the exhaust system exploded. The muffler couldn't take the pressure and split at the seams. (The driveway was covered with soot).
The hole was patched with aluminum duct tape, backed up with a large coffee can, held in place with large hose clamps.
We were expecting our first and spending the money on a new muffler for daddy's toy was not in the budget. The coffee can has worked so well that it has not been replaced yet (but the new muffler is in the garage moving up the punch list).
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
53Movinon #987775 11/21/2013 5:07 PM
My gas pedal is an old belt buckle. The line to my coolant overflow tank is a piece of copper tubing coiled up (think moonshine still).
now that's creative, anybody remember asbestos cloth sold? Wrapped that around mufflers a few times. I've seen; 2x4's for bumpers, coat hangers for antennas and on one occasion a screwdriver for a shift lever. Anything to keep them going.
53Movinon #987823 11/21/2013 8:58 PM
Is that an inspection sticker on it?
papas52 #987827 11/21/2013 9:08 PM
Inspection sticker on the window.
Parking sticker on the bumper.
It was street-legal in VA and in NY.
The original license plate holder nicely bolted on the top of the bumper. The screws were non-original wood screws. As you can see, I tried to keep it stock-looking.
told by original owner that my 52 Korean war era truck came from factory with a 2x4 as a rear bumper.
53Movinon #987833 11/21/2013 9:30 PM
A wood rear bumper was not listed as an option in 1952 (a curved, painted, spring-type steel bumper was the option in 1952). The dealer might have put on a wood rear bumper (original-style bumper brackets would have needed to be bent, too).
53Movinon #987834 11/21/2013 9:31 PM
Junction box cover used to cover enlarged hole for master cylinder
Master cylinder cover
tclederman #987846 11/21/2013 10:31 PM
I think he meant wood for transit only with metal bumper dealer installed. however, the installed bumper sounds like what is described. thanks.
53Movinon #987887 11/22/2013 1:58 AM
.... back when house trailer tires would fit a car I would buy them up when I could for Cheap. They were 6 ply and when the tread was gone they made good racing slicks for my 56 Chevy. I could run them a month after the first site of the thread showing smile
...used black electrical tape to black out part of the grille on my 59 impala.
Achipmunk #987915 11/22/2013 3:25 AM
This has very entertaining, but I do'nt think I can use any of these C.I's Thanks anyway guys.
53Movinon #987916 11/22/2013 3:27 AM
W Online: Content
I have a quart mason jar for an overflow bottle.
Wayne
1989 Silverado
53Movinon #987952 11/22/2013 6:10 AM
Of course there's the ever popular valley tin with pop rivets and roofing tar to fix rust holes in the floorboards.
And bungee straps to hold the hood shut.
Rich
1947 Loadmaster
53Movinon #988201 11/23/2013 1:34 PM
Was doing Vintage Air in a customer's car, it had the cowl panel repaired with a piece of road sign.
My truck has a ratchet strap for the hood safety catch, wood wedge in the window to keep it from rattling, and the ever-popular bungee strap battery hold down.
In my old '66 Chevy truck, I had a hose clamp around the 3 speed linkage at the bottom to convert it to shift an automatic trans. Had to count the detents in the tranny to shift, but it worked.
53Movinon #988219 11/23/2013 3:39 PM
The wood bumpers would outlast any plastic bumper on today's vehicles. A whole lot cheaper to replace too!!! Two or three vertical wood bars on it and you had a great pusher. You could dress the bumper up and give it character with strips of tire tread nailed to it. A tin can and 2 hose clamps repaired many a hole in exhaust pipes.
1939 Chevrolet Stake Truck
rickmg #988305 11/23/2013 10:53 PM
I had forgotten about the tire tread trick.
