1 members (MickeyP),
110
Mod | | | Forums66 Topics128,193 Posts1,057,253 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2013 Posts: 5 New Guy | | New Guy Joined: Nov 2013 Posts: 5 | Hi guys I'm new to the bolt I just grabbed a1954 Chevy 3100 outa Portland Oregon .I love it already and am looking forward to the restoration. can any one tell me if there's someone in Vancouver who can help me with steering issue it's super sloppy so I'm hopin to fix or replace it . so much to learn any help is appreciated.
Steve | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Steve's 54, welcome, have you checked the tie rod ends, drag link ends and kingpins for wear? If that stuff is okay then maybe your steering box needs an adjustment/overhaul, hope that helps. | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | Hi Steve, Welcome to another 54 owner. I brought my 3100 up from the Seattle area a couple of years ago. Have you had an inspection yet? Or is it not road worthy yet? Post some photos when you can and maybe we will run into you one day. The guy (the god) of trucks is 3B. Bobb knows these things inside and out. Again, welcome. John | | | | | Joined: Nov 2013 Posts: 5 New Guy | | New Guy Joined: Nov 2013 Posts: 5 | Hi John I have not yet had it inspected is there a time limit. I was hoping to paint it and get all lights working before inspection. Do you no does it have to be inspected by crappy tire or can it be third party. thanks and likin your ride
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | Steve, no time limit, but inspections need to be done by a licensed inspection station, even if your local CT is one, I wouldn't trust them to not find a bunch of things they'd want to sell you before they'd sign off - find an independent garage that will do it, but make sure everything works and there's NO rust holes anywhere
Bill | | | | | Joined: Sep 2006 Posts: 1,997 Big Bolt Forum Co-moderator | | Big Bolt Forum Co-moderator Joined: Sep 2006 Posts: 1,997 | Hey where are you located? I'm in Maple Ridge, and took my front end apart as soon as I got my truck. I haven't done the steering box, but it's next. A day without laughter is a day wasted- Charlie Chaplin When wrestling a grizzly bear, you have to keep at it until the bear gets tired, not when you get tired. 1948 Chevy 2-Ton | | | | | Joined: Aug 2013 Posts: 10 New Guy | | New Guy Joined: Aug 2013 Posts: 10 | RIV does not apply to vehicles older than 15 years,you can get your OOP inspection at the shop of your choice,perhaps one of the members here can suggest a classic/collector vehicle friendly shop.As for front end slop,it can be one thing,or everything,you will just have to check it all and replace accordingly. | | | | | Joined: Nov 2013 Posts: 5 New Guy | | New Guy Joined: Nov 2013 Posts: 5 | I'm located in coquitlam. Good to no that I don't have use crappy tire they just don't understand old trucks. My front end has been swaped to a camaro clip so it has disks but stil has old steering box everything seems tight and I adjusted steering box ( probably wrong) still sloppy. My truck has a 394 olds motor so no room for power steering . I guess when it comes outa paint I'll rip out old box and rebuild it . | | | | | Joined: Sep 2011 Posts: 305 Shop Shark | | Shop Shark Joined: Sep 2011 Posts: 305 | I couldn't transfer the title to my name until it passed inspection, so I rushed to get it done. It was unnerving, doing the work so it would pass but it still "belonged" to the former owner. I had a great guy do my inspection. He was very "old truck" friendly. His concern was that the brakes were good and the front end was safe. I'll see if he is still doing inspections?? Ya, stay away from Cdn Tire!
| | | | | Joined: Dec 2003 Posts: 2,953 'Bolter | | 'Bolter Joined: Dec 2003 Posts: 2,953 | Ditto the comments on crappy tire. Those guys work on commission. | | |
