| | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 16 New Guy | | New Guy Joined: Nov 2012 Posts: 16 | need pictures of installing headliner in 51 suburban which bows go where and how thanks | | | | | Joined: Apr 2013 Posts: 119 Shop Shark | | Shop Shark Joined: Apr 2013 Posts: 119 | You bought it dissembled -- bows were not labelled & numbered? | | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | If you bought the cardboard headliner from one of the vendors be prepared to be disappointed because it probably won't fit. I ended up buying 2 of them just to have enough pieces to do the whole thing. I had to make paper patterns and custom cut the pieces to fit. Looks OK once I got it in. I had help from 2 other motorheads. Attempted to do it alone. Didn't work,not enough hands. Somewhere in Panels and burbs there are pics of my installation. I am not computer savvy enough to post a link for you and I never could master the very complicated search feature on this site. Good luck on your headliner.
Weeds | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You start from the rear and work towards the front. Here are some poor photos of installed panels in a 54/55 Suburban. Earlier Advance-Design years would be the same, except at the windshield. You might want to seal the upper-side (and edges) of each panel (piece of cardboard) - epoxy primer or maybe a varnish. You can find out where each bow goes by "dry fitting" them. Each piece will fit in only one of the locations. | | | | | Joined: Nov 2001 Posts: 1,517 'Bolter | | 'Bolter Joined: Nov 2001 Posts: 1,517 | From my panel truck, and suburban experiences,,Its easier and a lot less headaches to have an upholstery shop put a cloth headliner in. I insulated it first, and they did a beautiful job on it. Less than 500.00. including the extra material for me to make the side insert panels. | | |
