11 members (Gdads51, Joe H, HandyAndy, greenie-reddy, Simso, 1955 1 Series, Southerntruck, Gib70, 3B, Peggy M, 1 invisible),
127
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,103 Posts1,056,183 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | My 53 Chevy pass door has an outer door glass window rubber stapled to the door. Is this the correct rubber and where can I find the staples? Also is there still a tool made to install the staples?
1953 Chevy 3100 261 and SM420 53Chevy 31001953 Mack Firetruck 1972 Porsche 911 1986 Honda Goldwing
| | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | Mike, those rubber strips just slide into the "channel". I've never seen them stapled in. On mine I put them in and pinched the end of the channel a little so it would "crawl" out the ends. Now the "fuzzy" strips are stapled in. I glued mine in with super weatherstrip adhesive and have had no problem for two years. The vendors do sell the staples for putting the fuzzies on. It'd be good for you to view Denny Grahams picture trail of him doing his originally with the staples. ...and I hope we're talking about the same things  | | | | | Joined: Oct 2012 Posts: 233 'Bolter | | 'Bolter Joined: Oct 2012 Posts: 233 | Thanks Alvin, I should have checked Denny's site first.
| | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Alvin's got it covered, the rubber just slides in but the cats whiskers get stapled in. You can buy the staples from the vendors but they are not the correct width for the original holes. I made a die set to bend up a batch on the correct center line: http://www.pbase.com/dennygraham/image/123537640Step thru the 'next' four photos and it shows you what you have to go thru to transfer the holes to the channel and install them with the staples. Denny G
Denny G Sandwich, IL
